Question about Lanier VW-160T
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it shows is 0 under "total units". How do I get the features to work so I can know where I am in a tape and go back to a certain area? Thanks! P.S. The screen below would not lef me select a Lanier VW260, only a Lanier VW-160T which was the closet thing but not right.
  • 207 Answers
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Posted on Dec 09, 2009
Need a new rewind motor for Lanier VW260 brianz@netspace.net.au
Posted on Mar 20, 2011
SOURCE:
How do I erase the tapes on a Lanier VW-210
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Jan 13, 2012 | Lanier Audio Players & Recorders
I have a Lanier Transcriber Model V W-210. Today the fast forward and the reverse did not work. I could hear a motor sound, but the tape did not advance or reverse. The "listen" worked, as did...
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
Sep 20, 2011 | Lanier Audio Players & Recorders
While dictating on the Lanier VW-260, the machine suddenly starts beeping - a rapid series of beeps, as if the tape is at the end. We thought maybe it was a bad tape. But that is not the case. It keeps...
Hello the alarm that you are listen is the end of the tape alarm the reason it detect a fast motion and is warning you that the tape is almost to the end but if you don't agreed that the tape is almost to the end your unit needs service you can Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Apr 14, 2011 | Lanier 260T Desktop Cassette Voice...
I HAVE THE LANIER VW 110 TRANSCRIBER; I PLUG IT IN AND GET NOTHING. COULD MY POWER CORD BE BAD?
Hello is possible that your power supply is bad or may be just the jack on the unit you have two options you can Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem or try a new power supply at http://www.tvps.com/Products/Lanier-APS-160-Desktop-Power-Supply---New__LA-APS160.aspx
Apr 14, 2011 | Lanier VW-160D
Hello there i have a lanier copier model ld 160c color copier everthing work fine and functional acceipt i can not make full color copy, when i press the full color button then the display panel show up TO...
Hi, somehow the external key counter option for your copier got turned on. This option is typically used for coin-operated copiers such as those found in libraries. You can turn this option off by doing the following:
- Press the User Tools button - Select System Settings - Select Admin Tools - Select Key Counter Management - Choose Off, or de-select the full-color option if it is selected. - Exit out of User Tools
Now you should be able to copy normally!
Dec 02, 2010 | Lanier UNKNOWN
I have a Lanier model VW 260 transcriber. 1) how do I erase old letters? and 2) does it have the auto rewind feature? (when I release the play pedal it goes back so many seconds) Thank you. Laura...
Hello Laura
Yes your unit has the option for erase Just hold down the REW and Telephone button at the same time make sure that you really want to erase the tape and the auto back space when you relase the foot pedal is the button located inside the front door they called Recall thats for adjusting how long you want to go back. thanks and good luck, if you ever need any type of accssesory please go to at www.tvps.com for large selection for professional Transcription units service and accessories http://www.tvps.com/Departments/Dictation-Accessories/Headsets/Cassette.aspx
Nov 24, 2010 | Lanier VW-160T
Lanier VW 210 transcriber beeps like it is at the end of the tape
There is a sensor that detects tape movement. Unfortunately they do go bad and will probably need to be replaced.
Nov 26, 2008 | Audio Players & Recorders
Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
Lanier Transcriber unit will not play
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
Mar 02, 2008 | Lanier 260T Desktop Cassette Voice...
Lanier VW-160T Logo
263 people viewed this question
Top Lanier Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
