Question about Star Manufacturing Star Party Headset Microphone Toys Ipifc27430 Pretend P
Broken piece I have the Star Party Microphone. The piece that hold the microphone has broken. Can I order a new one?
  • 906 Answers
Good day,
hope this link below will solve your problem.
toys
Posted on Jul 29, 2010
SOURCE:
How do I take apart a beta52a?
Unscrew the grill and look for a plastic piece that holds the capsule in place. This plastic piece also can be unscrewed and will allow you to reach the PC board inside. Check for broken wiring (most common problem) but low output usually indicates a damaged mic capsule that must be replaced.
Feb 18, 2013 | Shure Beta 52A Professional Microphone
When i talk the other party is hearing big noise
TRY TO CONNECT TO OTHER PC'S MICROPHONE JACK, MAY BE THE WIRE IS BROKEN OF YOUR MICROPHONE.
Aug 19, 2011 | Compaq PC Microphone (Black or Beige)...
There's no sound when I try to record video. is the microphone on it broken? It's brand new
There are two microphones for stereo, it's unlikely. Here are some suggestions:
  1. You're holding down the button while recording. Holding the button mutes sound; let go.
  2. You've got your finger over the microphone(s).
  3. You've turned off the playback volume by mistake; play a movie and use the ZOOM lever to adjust.
Mar 06, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
I have a nokia 5250 when i answer calls other party is not able to hear my voice, but when i use my headset they can hear me
most likeley your internal microphone is broken. You need to bring your phone to an expert who will replace your microphone.
Hope it helped,
Franz
Mar 02, 2011 | Computers & Internet
I have made conection , make call I can here person but cannot answer parrotv5.10C
Has the Parrot ever worked correctly? I would think that being you can hear the other party, but they can't hear you that it would be the microphone. The microphone wire is very thin and can easily be broken if it is pinched or crimped. If you have can easily access the brain (blue box) you can try and plug in a different microphone (headphones can work as a microphone to test this, just plug them in). I've had this happen after an installation where it worked correctly for about a week.
Mar 01, 2011 | Cell Phones
Microphone makes a static sound when it gets moved. The static comes through the speakers when the microphone is held in different positions. Could it be the cord or the connection to the mic?
Make sure your connections are clean and tight. There may also be an intermittant or broken wire in the cord. See if you can narrow the problem down by holding some parts of the wire stationary and moving other areas. gently shake the mike with the set off and listen closely for loose parts making noise. (The idea is to eliminate the areas that are good and what's left is broken.) Hope this helps
Dec 29, 2010 | Magic Star Karaoke Microphone
The microphone was dropped and the bottom tab on the cover for the mute and on/off switches was broken off. Is there a parts manual for this microphone so I can see about ordering a new cover?
This is a COMMON problem. Contact Shure directly for parts. Tell them your model number and they probably know the part number by heart. I have one with the same problem.
A POSSIBLE solution is to put a small piece of thin double backed adhesive tape.
Apr 20, 2010 | Shure UT2 / 58 / PG58 Professional...
Cord broken for Magic sing microphone
If you need a cord or any accessories please contact or email me at b2ssm2n@yahoo.com. i'll be glad to help you.
Oct 22, 2008 | Magic Sing Along Consumer Microphone
Mute button is broken and the section where the 9 volt battery goes
you have two choises:1-buy anew one;
2-buy an used one from the used msrket and replce defective component.
Dec 06, 2007 | Shure Beta 58 Microphone
Radio Microphones.
See the following for repairs:
http://shure.custhelp.com/app/answers/detail/a_id/4053
Nov 08, 2007 | Shure (LX287CC) Professional Microphone
Star Manufacturing Star Party Headset Microphone Toys Ipifc27430 Pretend P Logo
343 people viewed this question
Top Star Manufacturing Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Star Manufacturing Toy Expert? Answer questions, earn points and help others
