Trying to print a B & W photograph and print comes out pinkish. Also does not print straight.
The program that you are using to print the graphic will have an option of print in File. In print you must set to print b&w. Then only will the printer print pure b&w. Regarding not printing straight, the rollers that pull the sheet are mot mashing correctly. Firstly clean then with a moist soft cloth and then print again after the rollers have dried up.
Just go to printer's properties and select color ---> Color options---> Print in Grayscale ------>Select Black print Cartridge only then I think your problem is solved. If it not fulfill your desire then you need to change your cartridge.
Thanks & Regards
Rajneesh pandey
