Question about Nokia IP350 (NBB335F000) Firewall
Nokia IP350 very initial stage problem
I'm beginner in Nokia Firewalls...Whenever I try to boot my Nokia box it first starts with loading bootstrap & then prompts for :
Provide shell path or press Return for sh :
while it allows to do nothing on the prompt.What is the problem & how to resolve it ? Can anybody help me...???
I recently bought a Nokia IP350. I tried to boot it. but there is nothing come up in a hyperterminal. I am accessing via console. Can u help?
Posted on Apr 10, 2008
SOURCE:
How to reboot
See this image. Reboot is now called 'Restart'. You have to click the little arrow to see the options.
May 03, 2015 | Computers & Internet
Failed Windows XP Setup
sounds like a bad hard drive or it has bad sectors.hard drive regenerator software may help
Jun 25, 2017 | Computers & Internet
What folder is reboot in
  • Power is turned on.
  • Open Firmware code is executed.
  • Hardware information is collected and hardware is initialized.
  • Something (usually the OS, but also things like the Apple Hardware Test, etc.) is selected to boot. The user may be prompted to select what to boot.
  • Control passes to /System/Library/CoreServices/BootX, the boot loader. BootX loads the kernel and also draws the OS badges, if any.
  • BootX tries to load a previously cached list of device drivers (created/updated by /usr/sbin/kextcache). Such a cache is of the type mkext and contains the info dictionaries and binary files for multiple kernel extensions. Note that if the mkext cache is corrupt or missing, BootX would look in /System/Library/Extensions for extensions that are needed in the current scenario (as determined by the value of the OSBundleRequired property in the Info.plist file of the extension's bundle.
  • The init routine of the kernel is executed. The root device of the booting system is determined. At this point, Open Firmware is not accessible any more.
  • Various Mach/BSD data structures are initialized by the kernel.
  • The I/O Kit is initialized.
  • The kernel starts /sbin/mach_init, the Mach service naming (bootstrap) daemon. mach_init maintains mappings between service names and the Mach ports that provide access to those services.
Mar 08, 2010 | Apple MacBook Mac Notebook
Messed up Bootmgr on a Nokia IP350
Have you tried the steops below
1. Get the IPSO image you want to install.
2. Copy it to an internal host capable of FTP.
3. Connect to the console on the IP130 and start it up, when you
get past the bootmanager part where it shows the prompt
BOOTMGR[1]>install then ftp or help a few other commands
4. The interactive prompts should help you figure out what to do (like assign it an IP and ftp to the server).
5. Let it install the image and reboot.
Jun 15, 2009 | Nokia IP 350 Firewall
Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# bypass passwords
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Need to reset my Nokia IP350 password without flush my firewall licences
If you know the old password, simply go to settings and change password there. Or else, Try typing #pwd# and then "send. It will reset your password to the the last 4 digits of your phone number. Then you can reset your password back to what ever one you can remember.
Oct 26, 2008 | Nokia IP350 (NBB335F000) Firewall
Bootmgr Problem
hello I see your comment having some issues also with the same type of unit Nokia IP350 but cant logon ... missing original password ... Could you help me to reset password or send me a copy of the manual
Regards
Oct 21, 2008 | Nokia IP350 (NBB335F000) Firewall
SHUTDOWN
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Jul 12, 2008 | Garmin Nuvi 660 GPS Receiver
Problem with CLI
It sounds like the DB connector still has a few pinouts set up incorrectly. Nokia has exact specs listed for pinouts on their website. I recommend matching that up perfectly. If that doesn't work then the console port could be bad, but that is rare.
Apr 14, 2008 | Nokia IP350 (NBB335F000) Firewall
Basic Configuration Guide
http://www.nokia-asia.com/nokia/0,,80787,00.html This page will point you in the right direction. It is the specs and support w/ manual download. Good Luck, Tim
Jan 26, 2007 | Nokia IP 350 Firewall
Open Questions:
See all Nokia IP350 (NBB335F000) Firewall Questions
Nokia IP350 (NBB335F000) Firewall Logo
786 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
