Hi
after upgrading the DPH-80s to another firmware DPH-80m , the phone is locked and is not accessible !
tried to connect to web-interface by phone default ip address (10.1.1.80) but it seems to not up ! trying to ping it , scanning the range of the 10.1.1.0/24,8 , but no response from any ip address receives !
the phone LED is on , but has not any call on it ! tried to reset to default factory by pressing the *789*# but was not efficient !
can you please tell me how to resolve this problem ?!
I'm trying to work it with asterisk ! but stopped !
Thanks a lot
Regards ...
SOURCE: D-Link DPH-70L dialup IP phone changing IP Server.
Hello!
It sounds like you got this phone from the service provider you want to stop using.
If so, then the problem is that they have preprogrammed a provisjoning server in your phones firmware.
As long as this service is enabled their settings will overwrite any changes.
i cant find any information about this modell, but usually this menu is in a admin restricted part of the firmware and therefore it cant be changed without doing some serious hacking.
But before you give up try looking for settings in firmware menu (if it got a webui) that can point to this.
Voip equipment is usually cheap so its not worth the hassle if it cant be done easily. So before u put in a lot of hours in this problem consider buying new hardware.
SOURCE: Update the firmware of D-Link DPH-70s to support SIP protocol
this phones doesnt got support for standard SIP protocol, so its not supported by any major voip provider.
