Question about Lexicon Omega Desktop Recording Studio
WDM Driver failed to install is the first of four
"WDM Driver failed to install" WDM Driver is the first of four installs on the CD to install the Omega Destop Recording Studio. Lexicon Omega is the name on the Mixer. The directions say to plug the USB cord from the Mixer to the computer before starting install. I did that. Then when I select install the WDM Driver, ASIO Driver, Cubase LE Driver, and Help Files, nothing will get by installing the WDM Driver first. Other info. on the bottom of the mixer the label says Model No. LEXOMEGA SV Serial No. 00011685 RoHS.
I will be greatful for help with this problem. Thank you, Ted
  • Lexicon Master
  • 5,603 Answers
Make sure you verify that your computer meets the requirements for the Omega. I have one of these and it installed on an XP with no problem.
Maybe you have Vista instead of XP. OFTEN there are incompatibilities of Vista. If you have that or heaven forbod Windows 7, you may either need a different WDM or have to backstep to the XP operating system.
In short, VERIFY the requirements of teh Omega and its software with the OS and system you are trying to install it on.
A last thing to try is to install it while in "SAFE MODE".
Posted on Nov 13, 2009
SOURCE:
How do I install the driver for my bcd3000 .I get stuck on relaunch cotrolpanel
Check the following website to see how your problem compares with others that have a similar problem.
BCD3000 Traktor not working on new laptop
Feb 09, 2015 | Behringer Bcd3000 B-control Dj Mixer...
I can not install my bcd2000 to windows 7. the hardware and softwere
Four things to check:
Sometimes you must leave the device disconnected while installing.
You must turn OFF ALL anti-virus, spyware, anti-adware, popup blockers during install.
Sometimes you have to do the install in SAFE MODE.
Make sure the driver you have is Win 7 compatible.
Aug 10, 2011 | Behringer Control DJ Mixer BCD3000
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto...
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Apr 16, 2011 | Lexicon Omega Desktop Recording Studio
My kids lost the driver cd for my casio ctk-710. Where can I download the proper software for this?
The Casio support site has a page to download the latest driver and software; once you download it you can install the file (and save to external media):
http://support.casio.com/download.php?cid=008&pid=340&rgn=1
I hope this helps.
Feb 23, 2010 | Casio Music
How to fix Toshiba laptop with missing or corrupt file WINDOWSSYSTEM32CONFIGSYSTEM
There are many ways to attempt a fix with this error you could try firsta boot into safe mode then running msconfig
select the diagnostic startup then reboot in the normal way this might enable you to find your error.
If this fails click the LAUNCH SYSTEM RESTORE which maybe able to use one of your restore points created at an earlier time (usually before an app install) this may give you the fix you require.
Dec 14, 2009 | Music
Usb device not recgonized
Did the keyboard come with a cd?If so(which it usually comes with),put the cd into your drive and it may just run the drivers.If nothing happens,leave the cd in the drive and go to control panel/install new hardware tab in the control panel.Then it should display a list of programs on your computer with a question mark next to it to describe that it is not running correctly(make sure the keyboard is plugged in when you do this).Click on the line that says your keyboard or it may say something along those lines...Then it will opt you to use the internet or install the program manually.Select manually and it should search for the driver,and if your cd is still in the drive,it will find any driver on said cd and install it so your keyboard will work.
Any of these keyboards usually come with software anyways,so it should be on the cd.If you dont have one:look up casio on google and see if you can get the drivers from their knowledge base.
Sep 20, 2009 | Casio CTK810 61 Key Keyboard
Installation of driver usb yamaha to host
The best thinkg to do would be to use the Yamaha's support section on their website to find the latest driver pack for this keyboard.
Once you have downloaded this, just run the install file and this will load all the vital files you need on the computer.
Aug 31, 2009 | Yamaha Full-Size Keyboard
Lexicon Omega Desktop Recording Studio Logo
1,214 people viewed this question
Top Lexicon Music Experts
Michial Gueffroy
Gil Shultz
tmaree
tmaree
Are you a Lexicon Music Expert? Answer questions, earn points and help others
