Posted on Jan 08, 2008
I Can not Reset error -codes
I have an aficio 1018d And has the SC-541 error code i al ready change the part an try to reset the errors but i do not work, there is a way to reset the machene ????
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jan 08, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
2135
Points
8
Its a fuser error code, the machine won't go back to working unless you go into svc mode and clear the error. I suggest calling a local tech.
Ricoh aficio 1018d sc 544
Hello!
This code is related to a Fusing low temperature error.
You probably need to change Hot roller (or fusing rooler) and thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do njot have technical knowledge)
If you still want to reset the code tey this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Exit all the way out.
Turn the machine off and on.
Hope this helps you
1helpful
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
5helpful
2answers
What SC 541 is ?
sc 541 is a fuser error code. try these steps
press clear mode once
press 107
press clear/stop and hold it untill your screen changes to copy sp mode.
press copy sp on screen
off and on the machine. it shud reset its code. i am a Ricoh tech. email me if you are having difficulty. [email protected]
My aficio 1515 have a code SC541
sc 541 is a fusr error. please email me on [email protected] so i can email you a procedure to reset the code.
1helpful
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
1helpful
2answers
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
11helpful
7answers
2answers
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
11helpful
2answers
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
3helpful
2answers
SC 541
Take the fuser out and clean under the thermistors, and reset the code by entering test mode ( turn off printer hold down online and escape as you turn on printer selece 2 engine go to sp5-810 and reset this.
-Carl, please let me know if this helps.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
