Sony Playstation 3 (PS3) Console Logo
Posted on Nov 13, 2009
My PS3 was working for 10mon, one day the audio over HDMI started to crackle. On dolby encoded media it would crackle and skip with an odd distortion. If I use any audio output other than HDMI on the PS3, no crackle. Nothing changed in my setup, and PS3 factory reset had was no help.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Mar 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
Helped
2439
Points
23
Sound like ur speakers are failing lol im a genious right... u probabily figured that out try playing something else through ur system not ps3 if it still crackles u should think about changing your sound system
My receiver no longer gets a Dolby Digital signal from the PS#. it only shows an analog signal being available. I have switched the HDMI from Directv to the PS3 input in my reciever and it recognizes the...
To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
Good Luck.
1helpful
Cannot get dts surround. I am using a PS3 and the
DTS (digital theater systems) is the name for a company that has it's own proprietary digital encoding for the audio, just as Dolby Digital does. In order for your media to have audio output in DTS, it actually has to be encoded with the DTS software format, AND manually selected by the user to play in that format. Incredible Hulk is NOT encoded in DTS. Select a movie that has the DTS encoding by checking the rear label of the case on the format table.
1helpful
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
2answers
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
2helpful
2answers
Ps3 static audio
I just bought my PS3 and noticed this exact problem, Go into your audiosettings click hdmi. then go to manual. Uncheck Dolby 5.1. save your settings. This fixed the static for me. Sony should fix thier 5.1 drivers
2helpful
Denon AVR-688 Dolby Digital issues
IT IS ALWAYS BEST TO CONNECT ANALOG AUDIO IN ADDITION TO THE OPTICAL, COAXIAL OR HDMI AUDIO CONNECTION. IF USING OPTICAL OR COAXIAL CONNECTIONS BE SURE TO CONFIGURE IT IN THE RECEIVERS DIGITAL ASSIGNMENT AREA IN SETUP.
ALSO, ON THE FRONT OF THE RECEIVER IS AN INPUT MODE BUTTON, PRESS THIS BUTTON UNTIL AUTO IS DISPLAYED
7helpful
3answers
PS3 hdmi Audio problem Crackling Sounds
I CHANGED THE AUDIO SETTING UNDER HDMI FROM AUTO TO MANUAL AND I REMOVED DOLBY 5.1 FROM SELECTIONS.LEFT THE OTHER 2 SELECTIONS THAT WERE ALREADY SELECTED FROM AUTO SET FOR HDMI I HAVE NOT HAD AUDIO PROBLEMS SINCE.
2answers
Audio crackling, white noise, seems to be an overload
Ya I get a humming sound when the volume on my Daenyx is turned up to 1 quarter the volume,Does anyone else have this problem? These TV's have great picture and sound when the humming isnt there but I cant find to much info on them.I have heard that these tv's might be made by Daewoo but I cant confirm this,Does anyone know if this is right??
1helpful
6answers
Source always PCM, can't get Dolby-D
PCM is standard when using HDMI cables, you are passing an already decoded audio signal to the receiver and it outputs the sound and does nothing more. The reciever calls this PCM, your PS3, when pressing select should show that it is decoding the dolby digital HD. There is no quality difference in the two. PCM is the same because it is un compressed audio. So when using HDMI, no matter the signal that the movie or music is playing, wether it be dolby or DTS, you will see PCM when using HDMI.
82helpful
15answers
Go to audio options, and manually DE-select Digital 5.1. That should fix it. It did for me.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
