Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Posted on Nov 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hitachi lcd rear projection 50v500 television
My 52" Hitachi lcd rear projection 50v500 television has a large red spot on screen when turned on and you actually see it on screen as you are watching it.I paid $3273.00 for this and it is about to expire on extended warranty in December 13, what can I do? I need answers ASAP
Anonymous
Level 3:
Top Expert:
  • Hitachi Master 14,553 Answers
  • Posted on Nov 12, 2009
Anonymous
Hitachi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718696
Points
48227
THIS IS A VERY COMMON PROBLEM IN BOTH THE 50V500 AND 60V500---IT IS A BAD OPTICAL LIGHT ENGINE---MAJOR PART---WHOLESALES FOR OVER 600 DOLLARS!
IF YOU HAVE AN EXTENDED WARRANTY---GET IT IN FOR REPAIR!
There are already several class action lawsuits in several states concerning this problem in this model.
What happens is the lamp the set uses damages lens etc inside the light engine--the engines are now being sold on an exchange basis and are all rebuilt units---that are supposed to not have the same kind of problem as the early ones.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
1helpful
Large red spots growing in the middle of my 50v500 hitachi projection LCD screen
Hi, you have an Optical Engine fault. Complete assembly needs to be replaced. This page shows the most common Hitachi Optical Engine Faults.
Hitachi LCD TV Light Engine Optical Block Info
1helpful
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
1helpful
Large light blue spot when TV is on
It is a defective light engine and is not a user replaceable part. In most case the part will cost close to 1000 if not more.
TV red spot
Your light engine is going bad.
Red in Color Shadow
contact authorized servicer to do a memory initialization in the service mode
Very large red spot when I have no picture on the screen
yes, you probably have a bad crt, or color wheel that also would need to be replaced. You can try resetting the lamp hours, Actually, I BET YOU HAVE A BAD BALLAST
Help
I see a very large red spot on my screen now. I just replaced the lamp and it seem OK. Now I get a large red spot with no indicator lights. Is there a pending problem?
Hitachi 50V500 Red Spot
Deb,
Unfortunately if you're not a technician Hitachi won't even consider sending you a LE for install... They will confirm your status and have you fill-out several documents.
As to the other part of the question, the service manual won't help - there is a procedure for memory re-initializing and after performing that you still have the spot then LE is called for.. But again, unless you're a tech with those letters behind your name Hitachi won't accept the results.
That said, we have done several of these and Hitachi has been exceptional to deal with pre and post install.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
3answers
RED SPOT ON TV SCREEN
You got shafted!!!!!!!!!!!!!!!!!!!!!!
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
