Samsung Prostar 824 Keyset Telephone Logo
Posted on Nov 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
george peters
Level 3:
President:
  • Master 860 Answers
  • Posted on Nov 12, 2009
george  peters
Master
Level 3:
President:
Answers
860
Questions
0
Helped
609276
Points
3471
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programmingMy office has the Prostar 816 phone and the manual - 2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
  • george  peters
    george peters Nov 12, 2009
    To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
    with the handset down enter #20 the screen should say MMC DISABLED
    1) enter in 1 2 3 4 1 # (that enables programming)
Carl Navarro
Level 3:
  • Master 2,460 Answers
  • Posted on Nov 13, 2009
Carl Navarro
Master
Level 3:
Answers
2460
Questions
Helped
1155712
Points
7314
Close. Here's the set of instructions for a Prostar and Prostar Plus
Adjusting the Samsung 816 For Daylight Savings Time
Changing date & time on the Samsung 816
With Handset Down
Action
Display Will Show
1. Press #
"Programming"
2. Enter 04
"Disabled"
3. Enter 43211
"Disabled 1"
4. Press #
"Normal Date & Time"
5. Press #
"Programming"
6. Enter 55
"YYMMDDWHHMM"
7. Enter Date, Day & Time (See Below)
"98010111157"
YY= Year MM= Month DD= Day
W= Day Of Week (1= Monday, 2= Tuesday, etc.)
HH= Hour MM= Minute (Enter in military format)
8. Press #
Adjusting the Samsung 816 Plus For Daylight Savings Time
Changing date & time on the Samsung 816 Plus
With Handset Down
Action
Display Will Show
1. Press #
"Programming"
2. Enter 06
"Disabled"
3. Enter 43211
"Disabled 1"
4. Press #
5. Press #
"Programming"
6. Enter 55
"YYMMDDWHHMM"
"98010111157"
8. Press #
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 20, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1297
Points
Dial #20, then 1,2,3,4 then change closed to open by pressing mute then press #. Then dial #70 (display shows) enter current date and time, press # to store and exit.
  • Anonymous Jan 20, 2011
    PS - I know what you mean about the manual... not detailed AT ALL! We only have one phone line that rings through and nobody sits at that ext. anymore so everyone has to use # and then the ext to answer the call. I think I found how to make it so that other phones will ring but I gotta look into that tomorrow. My main problem is trying to figure out how to change the phone numbers in the speed dial! Manual gives directions on how to change my personal #'s but that's it! ANy help would really really really be appreciated!!! THanks!
Problem with phone
Call the phone company and ask them the question they should help or come around and fix. Regards Billy
Samsung Prostar 816
Did you try unplugging power cord for five minutes? often this fix the problem.
PROSTAR 816 SYSTEM WAS MOVED FROM OLD OFFICE TO THE NEW OFFICE. WE HAD 12 PHONES WORKING IN THE OLD OFFICE NOW ONLY 10 WORK. THERE IS ONLY ONE PHONE THAT RINGS. THE TIME AND DATE CAN'T BE CHANGED.
This sounds like you need a Samsung engineer to visit, however I have sent you the instructions for changing the date and time in the form of a youtube video, more info can be found at www.abbeytelecom.com. hope this helps
5helpful
I have a prostar samsung 816 plus and we have a number of phones in the office and only one is ringing, how can I make them all ring?
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
3helpful
Need to know how to change the time on my ProStar 816 phone system
2answers
How do i change the time on my samsung prostar 816?
with the handset2.gif down enter #20 the screen should say MMC DISABLED
2answers
Samsung Prostar 816
If you have a programming manual you can change the settings on your own. If not, you will need to contact the installer or a local interconnect company that services Samsung. It seems as though the memory switch inside the ksu is turned off. If that's the case, it needs to be turned on and if not, you either have problem with the ksu or the power outage was a brownout. Sometimes a very short loss of power can cause corruptions in memory, however I seriously doubt it in this case. Your system is acting as though it's memory has been set to default.
Good Luck,
BB
4helpful
Samsung Prostar 816
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
Some of the buttons don't work and the Hold function doesn't work
The Prostar 816 phone system can only use Prostar 816 phones. There is a rare larger Prostar system that can use other Prostar phones along with the 816 but typically was only installed in situations where more than 16 phones were needed. If you are looking at non-prostar phones like the Samsung DCS 12 then they certainly will not work.
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
