SOURCE: Samsung LN-5265F LCD TV is very slow to come on.
its the elecrolytic capaitors on the power supply.
goto www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound
it shows how to fix it yourself for only 'peanuts'
SOURCE: Samsung ln-t4671f clicking - and won't power up
This is common problem of the 46" LCD. The power supply board has caps defective. You can open the case, look for the power supply. Normally, you will see the two small caps pop up. Replaced those caps, the TV may work again. If it does not work, those FET transistor in the board have been damage. You have to replace the whole board. The board cost $150 or so. You can order direc from SS. Go www.samsung.com//us then look for Support icon. Good luck
PS: Circuitcity still sell stuff by website, you can go there and found complain.
SOURCE: My Samsung LN-t4671F LCD TV clicks for about two
The power supply board have dead capacitors are very common problems in LCD,Plasma tvs in used of 1,2 max 3 years.The power supply board is the board where the power a/c cord plug into it.Searches all around the power supply board for these dead capacitors,it alway bulges up it tops or puff up it tops.Replaced these dead leskages capactors.Or tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: my samsung ln-t4671f takes 3 to 10 minutes to turn
The power supply board is dying,that the board where the power a/c cord into it.Replaced the power supply board will stable and work as normal again.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
