Need all sansui codes for ge universal remote RM24914.
Hi, have ge universal remote RM24914. need all codes for sansui tv (has vcr, no dvd,[this tv has a few years on it....] with comcast cable). 'preciate any assistance, thanks much! sorry, do not know at this moment which model sansui..... that's why I would like all the sansui codes for this remote...... again, thanks!!!
Re: need all sansui codes for ge universal remote...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
You can find a list of supported devices codes for your RM24914 and other GE remotes that require a 4 digit code, here. (a list of device codes for use with GE universal remotes that require a 3 digit code can be found here instead). Additionally, the user manual for the RM24914 can be found here. You will need to download a free program called Adobe Reader to view these files.
I hope this helps and good luck. please rate my reply. Thank you.
Ok I do not have a code specifically for what you mentioned yet in checking all the Sansui devices, there are not that many and some codes repeat; So I listed all that I have for Sansui's: TV's: 0135,0310,0394. VCR's: 0310,0376,0377,0394,0256,0967,0303. CD's: 0666,0704,0723,0734. DVD's: 0394,0967. TV/VCR combo: 0310. TV/DVD combo: 0394. DVD/VCR combo: 0394,0967.
You will note that the BOLD ones repeat for many devices, give those a try first.
There is a $5 remote at Walmart that I know works for this Tv combo. You have to use the code search which cycles through 300 codes and I believe the one that works is the very last one. It is a GE remote that they usually have stashed by the checkout counters. & I believe you have to program each device on the tv individually.
I own a One-for-All universal remote, and my booklet says the setup code for a Sansui TV ( without a built-in DVD or VCR) is 0463. I can not guarantee that this number will work with your remote, but it is worth a try.
Code For Model JER422
Code
3168
for
Sansui
DVD
Code
3401
for
Sansui
DVD
Code
2010
for
Sansui
VCR
Code
2031
for
Sansui
VCR
Code
2111
for
Sansui
VCR
Code
2123
for
Sansui
VCR
Code
2130
for
Sansui
VCRif these dont work try http://remotefinder.rca.com/
and if you cant find one there then your remote does not support this device.
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
