Transcend (589307) Media Logo
Posted on Nov 12, 2009
Transcend 2GB pendrive showing 0 bytes free space and 0 bytes used space
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 20, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
777
Points
Kya baat hai.........
Christina34
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 23, 2015
Christina34
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1320
Points
6
What else have you found about this Transcend pen drive in Disk Management or Properties interface? Does it also show as RAW file system there? Or are you asked to format this pen drive before you try to access anything inside?
If so, your pen drive must be logically or physically damaged somehow due to RAW file system, the simple formatting process performed on this pen drive can help fix your disk problems.
But, you also should know that you'd better not format this drive in a hurry when you do left great important data inside. Merely download RAW file system flash drive data recovery software to recover pen drive data back before any format.
But, if this drive is not displayed as RAW, you'd better scan it with antivirus software to see whether it is virus infected.
Anonymous
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Dec 04, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
41
Questions
0
Helped
15124
Points
64
Simple thing format it,.................
buddy first u have to do boot ur window xp cd,......remember don't forget to insert the pendrive in usb after that when the dialogue comes where u have to format all ur drives in ur hard disk ,.......select the drive of ur pendrive,......and format it,.......but hardly remember,.when cd starting puttin system files on ur pc turn off ur computer,..........n after starting it,......u hv to again format by right clicking it,.......simple,..............
try it,........sure it will work,......... enjoy
Pen drive showing 0 byte
Do not use any more and get some data recovery freeware.
2helpful
2answers
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
3answers
32gb SD card is showing 0 bytes used space and 0 bytes free space
Try formatting the card and be sure the locking switch is in the off position.
4helpful
3answers
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
2answers
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
Can tot open pen drive
you format your pendrive
or
go for nearest transcend service centre
or
your your pendrive is out of order
Pendrive get detected but not display items
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
I
95helpful
12answers
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Top Transcend Electronics - Others Experts
NOEL
NOEL
Larry
August Brown
August Brown
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
