the Konica Minolta Bizhub C350 is by nature a slow printing machine the standard memory that the machine comes with is only 256mb and it can only be upgraded to 512mb . but there are some things you can do to help speed it up a little. touch the utility/counter button touch admin setting on the touchscreen enter the admin password touch system setting touch output setting touch print/fax output settings touch print select between page print and batch print=select page print exit all the way out of admin mode then reboot the copier tests have shown that this changed a print job from taking a little over 2 minutes to taking about 9 seconds to start printing keep in mind this is definately not the fastest printing machine on the market hope this helps thanks for using fixya
If your copier is connected to your network and you get this error, the answer is no. If you are getting the miss match error then the print job could be stuck in the que. This would cause it not to print. If you dont know how to clear the print job, restart your computer and try to print again using the correct paper size.
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start. Good luck!
first change driver, second print to hdd in printer, and then call this job from hdd and change copy amount. if this is not helping, then maybe the firmware is faulty, fw update is good idea
go to the properties of the driver and click on printing preferences and click on authentication/account track and the user name and password that you use to make a copy will have to be enter in this area to to print
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code. In Bizhub C350 that code means: C12C0: Hard disk recognition error You have the following options: - reinstall the hard disk - change hard disk or as a last chance change PWB-MFP
paper creases during printing
