I do have a polroid modul number is 3700 that tv wont turn on when i turn that tv that powe ligth go to re to green but i cant turn off that power liht
Hi, try disconnecting the connector from the headlight switch. If this doesn't turn the lights off, the problem is the body control module. If disconnecting the headlight switch DOES turn the lights orff, replace the headlight switch. You can probably get a used body control module from a salvage yard. They may also have the headlight switch, but you can get those at your local parts chain. To access the switch, pull the bezel straight out as shown below. The BCM is behind the fuse panel as shown below. Please let me know if you have any questions, anmd thanks for using FixYa.
sounds like you power supply board is going bad. Take the back cover off and check the powe supply board capacitors to see if any are bulging, leaking. Check the voltage with a multi meter reader. If you have any issues or questions please let me know.
you need to replace the flyback, you need flyback number 259296 you can get a replacement at the following link with free installation help so you can do the repair yourself. http://servicemanuals.vstore.ca/
