Hi foreylexy,
You actually don't need to install a driver for a router. The discs that the manufacture provide are actually just run a program to guide you through the initial setup. I'm using a router right now and I've never had to install a driver. If however, you are talk about the wireless adapters for use with the WRT54G access point router - then that's a different mater.
To access you router just plug an Ethernet cable into it and your PC. Then open a browser and type 192.168.1.1. This is the default IP address, unless you've changed it. The default login and password are both admin. You should now be able to make any changes you need.
Regards,
Spare head 2.
i cant find my disk to set-up my wireless-G 2.4 model/wrt54g
I purchased the wrt54g
about a year ago for my daughters computer in her room....her computer crashed about three months ago...now i can,t find my driver disc..how do i load the wireless adapter...
I lost disc and cannot hook up linkysis onto new laptop. Do I need to get a new set up disc or can it be done with out it? If so, how?. Where can a new set up disc be purchased?
problem with model wrt54g
