Televison & Video Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know how to put the tv on close caption
Anonymous
Level 3:
  • Master 3,741 Answers
  • Posted on Nov 11, 2009
Anonymous
Master
Level 3:
Answers
3741
Questions
0
Helped
974890
Points
10483
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
I have a Sony KV-27ts27 television that I bought secondhand, without a remote. I need to know how to turn on closed captions. When I had cable service with AT&T Uverse, the closed captions were working but...
Here is a link to the manual. It appears to me your set does not support closed captioning. It is too old. It mentions channel captioning, but that is for a channel identifier for reference. http://diplo-best.com/314.php?k=ac30c98e172782467c3895e8cba613ad&ID=87078&q=SONY KV-27TS27
1helpful
I have no remote, how do I get off close caption on a TS2554C101
There is a Menu button on the TV for the TS2554 C101. Press this button to get the OSD menu. Then press the vol +/- buttons to highlight Set. Use the Ch +/- buttons to get Closed Caption. Then press Vol+ or Vol - to get the closed caption menu. Use the Ch+/- buttons to set the desired closed caption setting and then press Vol + or Vol - to confirm the selection. Press Menu again to exit.
This will only help if the captions are being interpreted by the TV. If there are open captions, they will not go away. If the closed captioning is on at a set top box, you will need to turn them off using the controls for the set top box. (I know satellite receivers have independent captions available.)
I hope this helps. If your TV doesn't have a menu button on the set, you will need a remote that has a matching Menu function. Some universal remotes should have this feature.
3helpful
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2,3..now u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Closed Captioning
It should be listed under the Audio or Features in your main Menu..
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Closed captions
Closed Caption may only come on when you have the television muted.
Closed captioning
try uplugging the tv for a day if the captioning is still in customer menu then try to find a universal or replacement remote this remote may have dedicated captioning key there may be a button sequence on the front of the tv that will reset the customer settings
3answers
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Ratio issues
It sounds like your eprom has issues and needs replaced. Not expensive but you will need a tech.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
