Sony FD Trinitron WEGA KV-32FS320 32" TV Logo
Posted on Nov 11, 2009
Remote sensor is not working
I've tried universal remotes as well as the original and the tv responds to none of them
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 11, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1748
Points
15
TRY GETTING A SKY REMOTE THEY ARE PRE-PROGRAMED TO ALL SONY TV'S
1helpful
2answers
Universal remote codes
Hello
If your Technica TV asks for a four digit universal code; buy onw RCA RCR311B model remote control. The codes for Technica with this remote control are:
1004, 1006, 1009, 1010, 1013, 1025, 1035, 1045, 1051, 1060, 1061, 1075, 1078, 1103, 1122, 1123, 1205
If it asks for a five digit code, buy RCA RCR 312W model remote control
Codes for Technica with this remote control are:
10054, 10180, 10150, 10060, 10092, 10016, 10056
Otherwise, give me the Brand Name and Model Number of the remote control you have with you now, and let me search whether there is any code for Technica TV, with this remote control. OK.
Universal codes sylvania need tv
Universal codes are in ur tv univeral remote manual already.None of those codes work for ur tv brand.None of the codes people give u will work either.Return the universal remote where u bought it.Try website like Remotes.com to buy the tv original remote.
2helpful
Bought a 42pc3d-ud Lg Plasma tv from someone without a remote so i bought a new remote. i do i program it
This is a universal remote u bought wright?Check ur tv remote owner manual follow the instructions and program in ur tv universal remote codes for ur tv universal codes.If none of the tv universal codes of ur tv model will work,return it.Try website like Remotes.com to buy the tv original remote or very close compatible to the original one.
1helpful
The tv is stuck on a game channel and none of the buttons work such as the channel page, menu, select, guide, etc. I have replaced the batteries
Good day!
may I know if your remote is original or universal remote.
If your remote is universal you have set-up the remote code.Because universal remote is need to set-up every time it loose the battery or power.
If your remote is original and the battery is new.You have to do is replaced the IR sensor of your remote.
Thank you
2answers
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Universal remote has lost it programming and wil not operate tv. I need codes and to know how to enter them into the remote.The tv is a SylvaniaModel 6424TF Please respond. Thanks you Pauline
Hi, I have a few things for you to try.
1. Your TV "6424TF" seems to have problems with its IR "Infra-red" sensor going bad. This is a common problem with your model TV. If this is the case no remotes will work on your TV.
2. Because I do not know the model of your universal RCA remote I cannot tell you how to program it.. please supply the model number of it. Try looking under the battery cover. might be an "RCR..." number. I need to know this because all universal remotes have different codes and programming methods.
3. To know 100% if its your TV that's bad you will need the original remote for your TV. I have already looked up your original remote and you can purchase a brand new replacement that will work right out of the package (assuming your TV IR sensor isn't broke) here: RR0108UD for all sylvania TVs . no programming is necessary for this remote.
My grandson broke my original remote control for my toshiba tv how do I program a universal remote to work
In the manual it self,give all the codes for ur tv,none of them work?No,one well give u any other codes will work for ur tv.Return the Universial remote.Try this website like Remotes.com to buy a original remote.Yes,it cost alot more than a universal remote,but it ur tv original remote.
TV does not respond to remote commands,
I'm sure you've tried this, remote batteries is most common cause.
Make sure sensors on TV and remote are unobstructed(remote only works if line of sight to sensor is clear) and clean. Windex and Qtip. Damaged/dirty/defective remote, try different if possible (universal). If none of above works(99% chance), extreme longshot is TV circuitry.
No response from remote
Remote problem could arise from either tv or remote. First check your universal remote on some other tv and if it is okay your tv's infrared sensor has stopped working. You can get it from the local component shops, take the existing sensor with you. This problem could be from the micro processor in rare cases. Best of luck.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
