HP Officejet Pro L7580 All-In-One InkJet Printer Logo
Posted on Nov 11, 2009
My officejet pro L7580 printer is printing horizontal black lines on my pictures. What can I do for this?
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Nov 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
32745
Points
11
You more and likely would need new printheads, this particular printer is one of the worst HP ever produced. i have these in the shop weekly.
2answers
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
1helpful
2answers
The following printhead has a problem black yellow k y
I have brand new print head and saids that there is a problem with the printer head and will not print nothing the black will not go to the print head need code to over ride and print something in black and white I've tried to shut it down and restarted for 30 sec. and for 15 min's did not work keeps coming up that there's a problem with the printer head model #C8187A-013 serial # MY76553H2 series Officejet Pro L7580 All-in-One email: [email protected]
3answers
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
3helpful
2answers
Black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
I have an HP Officejet Pro 7580. When printing in
I think ur catridge must be empty plz fill ur catridge and then check
8helpful
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
2answers
My HP officejet Pro L7580 says the printhead has a problem
Re-insert the print cartridges. It is also possible that the heads are burnt. Get a new set of print heads (black/yellow) and install to the printer. If problem persists, clean the contacts on the printers. Use acetone + cotton swabs.
Hp l7580
Hi, it sounds like a faulty ink cartridge. Try changing the black cartridge and see if this helps
k24674
Grand Canyon Tech
Grand Canyon Tech
