Question about Casio G-Shock GW300CA-1V Wrist Watch
How do you change a casio g shock from military time to standard time display?
  • 714 Answers
Http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 09, 2010
2 Suggested Answers
SOURCE:
  • 2501 Answers
SOURCE: casio g shock dw-9052 how to change from military
You can get instructions from the Casio web site which will tell you how to set your watch..
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Feb 22, 2010
How do i get my g shock out of military time
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press adjust again. 12H or 24H will be flashing at the bottome. Use the receive button to cycle the mode. When it's what you want, press adjust.
Mar 14, 2011 | Casio G-Shock GW500A-1V Wrist Watch
I have a Casio G Shock 2548 watch that I would like to change to military time. How do I do this?
I presume you don't have the manual. If 2548 is the caliber number go to this Casio link for full info in PDF format.
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2548&submit.x=57&submit.y=5
I hope you find your info here. Thanks, Bill
Aug 31, 2010 | Casio G-Shock GW500A-1V Wrist Watch
I have a G shock 1659 model, kinda old, but I
Press Adjust / Hit Mode until the minutes or hours is flashing. either one will do. When on or the other is flashing press the "G" button for the light. This becomes the switch for 24hr/12hr.
May 14, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I have a G shock 1659 model, kinda old, but I don't know how to get it off military time, how do i change it to standard?
go into your menu setting and after the time set it should allow you to choose between 12hr and 24 hr modes
Mar 25, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Change time from Military to regular time!Casio G shock
If you haven't got instructions on how to do this, you can get instructions from the Casio web site.
Accept terms
Mar 20, 2010 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
I have a casio 2747 and i am having setting the time digitally because i dont want military time and it refuses to change plzz help me
On the Casio 2747 you can easily change between 12-hour and 24-hour (i.e. Military time)... Follow these steps:
1. Make sure you are in Timekeeping Mode (i.e. digital display shows date at the bottom).
2. Press the "D" button (i.e. bottom-right button) to toggle between 12-hour and 24-hour timekeeping.
Note: 12-hour timekeeping mode will display an "A" or "P" for AM and PM.
Mar 10, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Casio g shock dw-9052 how to change from military time to standard time
Accept terms
Feb 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 | Watches
Casio G-Shock GW300CA-1V Wrist Watch Logo
1,019 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
Ekse
Are you a Casio Watch Expert? Answer questions, earn points and help others
