SOURCE: psp wont read disc
your lasers Dirty or damaged.
These usually last about 14-18 months sometimes longer, depending on amount of use. ( operating hours ) your best solution, is to try blowing into the UMD Drive, may be lucky and remove a speck of dust. Or you,ll need a UMD Replacement.
Best-cheapest place is e-bay.
You,ll also get fitting instructions. Alternatively is to take it to a repair shop. But don,t expect much change out of £75.00.
Mike @ compurepair.
SOURCE: PSP can't read UMD
My sons had this happen to him this morning... we tried to reset and hard reset... nothing worked... after seeing a bunch of postings about the laser, I used a pen to move move the laser with the unit off... I just pushed it sideways and slid it out of position a bit... anyway, it worked... it's almost like the laser was just stuck...
SOURCE: My psp wont play the UMD and a cliking sound is made
get in toutch with sony thay will advise you wetther it can be fixed or if you need a new one
SOURCE: my psp wont read the games
hi..
Have you upgraded the firmware? if not go to sony's site and download
the firmware and from there load it to your memory stick and update.
this should resolve the issue. you can also update the system if you
are wireless and can get internet access on your psp. if this does not
work get in toutch with sony thay will advise you wether it can be fixed or if you need a new on..
thank u
rate me
SOURCE: my psp umd drive will not work, no clicking... no
Open the umd door there is a small switch in the upper left corner if the tip is broken off of it it wont play umd's .The switch tells it the door is closed.
