Question about JVC Everio GZ-MG30 Camcorder
I dropped my camcorderd and the drop detection will not go off. displays HDD error I tried the reset button, and going into main menu to turn drop detection off. Continues to display HDD error.
    New Friend:
UR HDD IS NOT SUPPORTING THE CAMCORD I THINK ANY CONNECTION GET LOOSE GIVE THAT FOR REPAIR....
Posted on Nov 11, 2009
6ya staff
SOURCE:
Bizhub c 450 error c 3752
Fuser Heat Error. Sometimes this code can be cleared by using the reset procedure outlined below. If the code returns then you will need to have the unit serviced.
Reset Procedure: 1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
Apr 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
I have an 17" aopen
Hello
You've said that there is no start up with your hdd even you hdd is defective your CPU will turn on and have display in your monitor try to turn your computer on then push the button delete or a f1 button it depends on your bios that you have using. If your PC tun and display the bios it means your motherboard is good. Then in the bios set up put it in the main section you will see if your HDD is detected by your PC if not then you HDD is defective o have a lose contact on its connectors.
If you don't have a display try to check if your CPU have a video card. Turn off your PC then pull out VGA connector that are connected to your computer then pull out the Video card in your motherboard which connected to a PCI slot then tun on your pc using the on board VGA connector which is located at the back of your CPU which is beside the parallel port and on the lower of the mouse and key board connectors. If the problem is still there try to clean your Memory cards which is located inside your CPU unit and located at the left side your motherboard and beside your processor. Clean it with a pencil eraser. Then put it again in your motherboard. If problem is still there. Try to check your power supply may it dropping voltage where the did not full fill the requirements of your computer. Hope this will help.
Jul 18, 2011 | Computers & Internet
Sony cybershot dsc-w290 after a recent dropping of the camera when we turned it back on we get this message "turn the power off and on again" same thing happens each time.
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Jun 16, 2011 | Cameras
Bizhub c450 error c3752 Guillemin
Reset Procedure:
starts.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 16, 2010 | Konica Minolta bizhub C450P Laser Printer
Motor error on lexmark printer c540
Motor error comes up when motor of the printer fails to turn or run. Here's what you can do:
Run motor detect (NOTE: You may need to run motor detect procedure two or three times to be successful.). To run motor detect, you need to go to the Diagnostic Menu.
1. Turn the printer off.
2. Press and hold Left and Select.
3. Turn the printer on.
4. Release the buttons when the installed memory and processor speed displays. Scroll down to Miscellaneous Tests. Press the select button
Motor Detect
This test initiates an automatic motor detection process that should be performed whenever the controller board
is replaced.
To run Motor Detect:
1. Remove the imaging unit and the waste toner bottle.
2. Reinstall the right cover assembly.
3. Close the front cover.
4. Enter Diagnostics menu (Turn the printer off, press and hold Left ( ) and Select ( ), turn the printer on,
and release the buttons when the installed memory and processor speed displays.
5. Select MISC TESTS in the Diag Menu, and press Select ( ).
6. Select Motor Detect, and press Select ( ).
If you press Select before closing the front cover, a message appears: Close Cover. Press Select.
Motor Detection In Progress… appears.
The motor detection process takes about 10 seconds, and stops automatically.
Detect Complete. Rebooting… appears, and the printer performs a POR (Power On Reset).
If the motor ran, the test was passed. If the motor did not run, the test failed. If problems persists, the printer might need to be serviced or exchanged depending on the warranty/entitlement.
Apr 14, 2010 | Lexmark C540N PROD SPECS TBD Printer
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
RCA H100A
drop it about 2ft on hard surface if it does not work try other way
Feb 27, 2008 | RCA H100 MP3 Player
Konica 7020 copier
what happens when u run L-detect. Make sure the sensor near the drum sep claws in the drum unit is clean. Any toner or setting powder on this semsor will give u errors while running L-detect.
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
Error code 070028
The 070020 error means:
"One of the Drop Detection errors has occured - or, during the Drop Detection no drop was detected.
Pen checking is set to OFF.
* Perform the drop detect calibration,
* Troubleshoot the catridges and the drop detector.
* If required, replaced the service station, .
* Check the cable assembly and the main PCA.
Nov 23, 2007 | HP DesignJet 750c InkJet Printer
JVC Everio GZ-MG30 Camcorder Logo
398 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
