Mitsubishi WS-55511 55" Rear Projection Television Logo
Posted on Nov 11, 2009
I HAVE A MITSUBISHI 55 INCH WS55511 REAR PROJ TV, WENT OUT OTHER NIGHT, REPAIR MAN WANTS OVER 400.00 TO REPLACE CONVERGENCE CIRCUIT, WHEN i DID TEST IT HAD THE GREEN LIGHT BLINK 2X THEN 2X WAS TOLD ONLINE IT WAS PICO FUSES POSSIBLY, NOW REPAIR MAN SAYS CONVERGENCE CIRCUIT REPLACE OR REPAIR? aNYONE KNOW ANYTHING ABOUT THIS ISSUE? CAN I FIX IT MYSELF, IF SOMEONE CAN EMAIL ME [email protected] THANAKS
Anonymous
Level 1:
  • Contributor 52 Answers
  • Posted on Nov 14, 2009
Anonymous
Contributor
Level 1:
Answers
52
Questions
0
Helped
14571
Points
93
Does the led stay blinking while on?
1helpful
I have same problem when I do the self diagnosis it blinks twice 10 times....any ideas?
Thats the code for a short. Which is almost always caused by the Convergence circuit. You can get the WS55511 Convergence repair kit from www.tvrepairworld.com which contains the parts and the CD with instructions
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
2helpful
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
I cannot correct convergence on my Mitsubishi ws55511
U know how to solder right?Tries these websites.Tv Repair World.com,Sopjimmy.com or Ebay.com.Just buy it with a instruction cd for tutoring.
1helpful
2answers
Got a Mitsubishi ws-55511 as a freebie a few weeks ago. Once plugged in it does nothing but flash the power light. Prior owner removed access panel but went no further. I am an audio engineer with lots of...
Thats an easy fix. The capacitors on the DM are known to fail . You can get the WS48511 - WS65511 DM repair kit at the following link which contains the replacement capacitors and the instructions on how to do the repair on CD which also contains the Service Manual
www.tvrepairkits.net
PROJECTION TV COLORS DISTORTED
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
1helpful
Tv won't stay on
hello,
After further inspection, I believe that you have a blown convergence IC. Most posts point for two IC's. I only have one. STK393-110. There are 12 - 3.9ohm 2w resistors around it . I think they may be bad as well. The 2 Pico fuses feeding that circuit (+24/-24) may be open also.
So, with that said...... Think we have the problem cornered?
MENACE1275
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
