Hi my n95 phone is in offline mode, when i select the general profile the massage is shown on the screen insert sim card.please help me how i can change the offline mode
Press the power button at the top of ur phone till u see the profiles available. then select offline mode to go into offline. and if u are already in offline mode, select general profile!
SOURCE: N95 on offline mode, not coming in general or
hi malik, you're still having the same problem though, now you know that your phone has the error..
try these steps on your N95 phone.
1. on your keypad, press *#7370# for soft reset
2. then, insert your sim back, check if your sim has been recognized, if it doesn't do step 3,
3. on your keypad, press *#7780# for hard reset once finished, insert your sim back and switch on. if the phone still doesn't recognized the sim, then do step 4.
4. on your keypad press *, 3, call key and power switch at the same time, to make a hard formatting on your phone and setting it back to its factory setting.
>> under above steps, you need to make sure that, battery is fully charge, if not, fully charge battery before doing all the steps above. don't forget to remove your sim every time you do the steps (so as the sd card if your phone has it).
>>>please make a note that, if all of the above steps has failed,or nothing happened and still you have the same issue, then go now to a phone repair shop and have them check your phone, it can be a hardware problem. if your phone is still under warranty, try not to do the steps above, instead, go back to that phone store and return your phone and show them your problem, so they can immediately replace it.
>>>also, make sure that your phone is network unlock and can be use with other network sim.
good luck.
