Broderbund Mavis Beacon Teaches Typing® 15 Full Version for PC, Linux Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I downloaded the program and installed it.after installing,when i went and to programs and clicked the teaching mode,windows says FAILED TO INITIALIZE WONDOWS.TRY STARTING THE GAME AGAIN.IF IT DOESNT WORK,TRY CHANGING COLOR AND SIZE RESOLUTION.IF IT DOESNT WORK,YOUR VIDEO CARD DOESNT SUPPORT THIS GAME.what should i do?
Anonymous
Level 2:
Sergeant:
  • Expert 267 Answers
  • Posted on Nov 11, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
267
Questions
0
Helped
63470
Points
729
Ok try doing a compatibility check . that may help to resolve the initializing of the drivers. to do that you go to the program right click on it . go to proporties .
there you will see compatibility if you are using xp and newer . check the system requirements on the game and see if a faster card is needed . check your system information by clicking start then all programs then ascessories then click system tools then click system information .
you can also check to see if there is a earlier version of the game that would be more compatible to your system.
Peter Dragonetti
Level 3:
  • Master 798 Answers
Peter Dragonetti
Master
Level 3:
Answers
798
Questions
Helped
209357
Points
2183
Try to look here :
http://support.riverdeep.net/fix.asp?isid=34619&prog=1294820294
and see if you have the minimum requirement, and try to reboot the computer if you not have done that after the installation.
Then try to look here if you need additional updates:
http://support.riverdeep.net/downloads.asp?list=defghijklm
If it still not working I will try to reinstall the software in this way :
Uninstall the software, reboot the computer, install the software and try again to open the program.
IF IT still not working you can contact the products support here :
http://hmlt.hmco.com/Contact.php
Have a nice day
Let me know
Please rate my answer
Windows 7 driver
Creative labs ct4780 is not supported by Windows 7. So you can download the driver for Windows XP and install it in compatibility mode. Click here to download the driver.
Configure the driver installation program to run in compatibility mode. To do this, follow these steps:
a. Locate the executable file for the driver installation program.
b. Right-click the file, and then click Properties.
c. In the PackageName Properties dialog box, click the Compatibility tab.
d. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
e. Double-click the executable file to start the installation program.
See: http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
tip
How to install or run older programs on Windows 7
Since the release of Windows 7 many of my clients have been asking me about program compatibility and which programs will run on Microsoft's new operating system.
Their concerns were mainly because of Vista not running very well and they thought that they may be in for some of the same type of compatibility problems that Vista had.
Before Windows 7 was released to the public Microsoft said in a statement that "Any program that works on Windows Vista will certainly work on Windows 7"
Microsoft has certainly delivered their promise and much, much more!!!
I tested both the beta and the RC (release candidate) editions of Windows 7. In October of this year I was so impressed with Windows 7 I went out and bought Windows 7 Ultimate.
I was glad i did because Windows 7 is being welcomed with very open arms, people are upgrading so i need to know my may around the operating system.
At first i was weary about programs not installing because of compatibility problems but the procedure to either install a program or get it running when installed is relatively simple and is the same way that Vista uses.
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
NOTE: Again, if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Sometimes you will get a message that says "This program may not have installed correctly, Reinstall using recommended settings and This program installed correctly"
It's up to you what you do from here, if the program works choose the latter. If your not too sure click on Reinstall using recommended settings"
So far (and i keep my fingers crossed) i have absolutely no problem in getting a program installed and running on Window 7. I will however provide more tips as and when they surface.
Please be aware that not all programs will work on Windows 7. These are programs which are mainly pre-XP like programs designed for Windows 2000, Windows 98/95.
on Dec 01, 2009 • Computers & Internet
Why can't I install download of Magix Movie Edit Pro 14 in Windows 7
You try try the compatibility wizard in Windows 7 to see if you can install Magix Move Edit Pro 14 in compatibility mode for Windows Vista.
To run the Program Compatibility troubleshooter
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
1helpful
I have Mavis Beacon teaches typing cd and I am trying to install it on windows 7 but it wont install i can only read the manual that adobe lets me, my questions is how do i download the program to windows...
What version of the typing program do you have? You have a few choices, depending on what OS runs the version you have.
If the program ran under Vista or XP (version 20 lists Vista compatibility), the compatibility mode is likely to work. For this, right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties.
If the compatibility mode doesn't work (for older versions of the software), you can use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software on the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
Your final option is to upgrade to the current version. The 25th Anniversary edition runs under Windows 7. Other editions are not listed as compatible at the Broderbund site. You can try the Microsoft Windows 7 Compatibility Center for more information on tested software. My ISP is slow to connect to the site.
I hope this helps.
5helpful
2answers
Need video driver dell optiplex 170l for windows 7
Drivers can be found at this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=PLX_PNT_P4_CEL_170L
However, you might want to consider the instructions below, as many people have had the same issue you're having with getting those drivers to work with Windows 7:
You may need to install the drivers in compatibility mode for Windows XP
To run the driver installation program in compatibility mode
Configure the driver installation program to run in Microsoft Windows XP Service Pack 2 compatibility mode. To do this, follow these steps:
1. Locate the executable file for the driver installation program.
2. Right-click the file, and then click Properties.
3. In the PackageName Properties dialog box, click the Compatibility tab.
4. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
5. Double-click the executable file to start the installation program.
3answers
I have a copy of starcon 3 but it won't install on my computer my os is windows 7 but it says that the game isn't compatable with my version of windows
Hi, welcome to Fixya. I hope my info helps you.
What it said is true. Starcon 3 is an OLD game, with compatability with win 95, and DOS. I think there may be a way for you to get to work though, right click on the installer program, and put the program in compatability mode, and tell it win 95 for the o.s. If that doesn't work, then download a program called DOSBOX, and run the installer with it, Dosbox is designed for just this sort of thing.
I hope that you do get it to work, as Starcon 3 was a really good game when it came out.
Splitcam dont run
Try running the application in XP SP3/2 mode. To learn how to do this for Splitcam and other XP based programs click on the link that i have provided below and have a good read on how to install programs on Windows 7.
http://www.fixya.com/support/r3554586-how_to_install_or_run_older_programs_on_
Regards.
"DLL loading failed"
firstly try to install the driver in vista in compatibility mode
If you really can’t find Windows Vista driver for your hardware, you can try to fool the driver installation program to install in Windows Vista
By using Windows Vista Compatibility Mode so that the driver installation program think it is installing in Windows XP mode.
or else download
from
http://download.cnet.com/1770-20_4-0.html?query=Veo+Stingray+Connect+Web+Camera&searchtype=downloads
or
http://www.soft32.com/download_176111.html
Error code 2352
http://service1.symantec.com/SUPPORT/nav.nsf/pfdocs/2003020714354306?Open&docid=2003020714354306&nsf=nav.nsf&view=pfdocs
To run the Microsoft Windows Installer if Norton AntiVirus was installed from the CD
  1. Insert the Norton AntiVirus CD into the CD-ROM drive.
  2. Do one of the following:
    • If the installation program appears, then click Browse the CD
    • If the installation program does not appear, then double-click the My Computer icon on the Windows desktop, and then double-click the CD-ROM drive icon.
  3. Double-click the MSI folder.
  4. Do one of the following:
    • In Windows 98/Me, double-click the WIN9x folder.
    • In Windows 2000/XP, double-click the WINNT folder.
  5. Do one of the following:
    • In Windows 98/Me, double-click the Instmsi.exe file.
    • In Windows 2000/XP, double-click Instmsiw.exe if you have Windows 2000/XP.
  6. In the next dialog box, click Yes.
  7. After the rollback has finished, then reinstall Norton AntiVirus.
    Follow the instruction in Reinstalling your Symantec program after a failed installation or after you see error messages to start the computer without any programs running on startup and then reinstall your Norton program.
If these steps do not fix the problem, then go on to the next section.
To run the Microsoft Windows Installer if Norton AntiVirus was installed from a downloaded version
  1. On the Windows taskbar, click Start > Find (or Search) > Files or Folders.
  2. Ensure that "Look in" is set to the drive where you downloaded Norton AntiVirus, and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, do one of the following:
    • In Windows 98/Me, type the following:
      instmsi.exe
    • In Windows 2000/XP, type the following:
      instmsiw.exe
  4. Click Find Now or Search Now.
    You might see many files with this name. Look for the file with this name that is located in either the Symantec_Norton_AntiVirus_2003 or the your Windows temporary file location depending on your version of Norton AntiVirus.
  5. In the Search Results window, do one of the following, depending on your version of Windows:
    • In Windows 98/Me, double-click Instmsi.exe.
    • In Windows 2000/XP, double-click Instmsiw.exe.
    This will undo the changes that were made to your system during the first failed installation.
  7. After the process finishes, then reinstall Norton AntiVirus.
Unable to run Professor teaches Microsoft Office 2003 on Windows Vista
click start menu setting control panel. add or remove program. remove that software. then. insert the cd try to install again and. finish the setup process. then click startmenu programs. see thre your program icon wil appear. click on it start using it. if any error comes. send error message. thanks
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
