E-Machines eMachines Desktop PC Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I FORMATTED MY HARD DRIVE AND REINSTALLED WXP HOME EDIT. AND I CANT GET TO THE INTERNET MY DEVICE MANAGER SAYS ETHERNET CONTROLLER SOFTWARE NOT FOUND. ANY HELP WOULD BE GREATLY APPRECIATED, THANKS TOM EMACHINES T3256 IS WHAT IM WORKING WITH.
Anonymous
Level 2:
Guru:
  • Expert 126 Answers
  • Posted on Nov 11, 2009
Anonymous
Expert
Level 2:
Guru:
Answers
126
Questions
0
Helped
45042
Points
553
There is a software disc that all drivers are free gift from Emachines, provided that this CDs is still on your hands.
Use that Software Disc Utility to install unknown LAN or Ethernet Device in your Emachines Desktop.
If your don't have that Disc then you download that freeware LAN drivers to the website manufacturer of Acer Emachines.
Or maybe you don't finish yet installing all devices such as VGA, & etc...
Click this link to open browser: www.acer.com
It's very easy to find out there.
Flashing white light, no connection with ethernet
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device You only need check the following if you cant install the driver Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html if these packages are not the right http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for tick in the box for windows software or all software box IE: Motherboard name Wireless or Ethernet driver you might have to try a few times to get it right
I cant format remoable disc in drive g
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Unble to formate the pendrive
Free Partition Software - MiniTool Partition Wizard Home Edition home1.png MiniTool Partition Wizard Home Edition is a free partition manager software designed by MT Solution Ltd. Our partition manager supports 32/64 bit Windows Operating System including Windows XP, Vista and Windows 7. Home users can perform complicated partition operations by using this powerful yet free partition manager to manage their hard disk. Functions include: Resizing partitions, Copying partitions, Create partition, Delete partition, Format partition, Convert partition, Explore partition, Hide partition, Change drive letter, Set active partition, Partition Recovery.
Hi i have just reinstalled xp home.cant conect to the internet its telling me i have no network adaptor or ethernet controller.worked fine before i reinstalled .i brought my comp second hand ftom acomp...
Pleasse reinstall your NIC driver (Network Interface Card). Check your device manager for make and model of your NIC. Download the proper driver to some other computer and put it on a disk which will work in your unknown computer (floppy if available, CD if no floppy)
Thanks for your interest in FixYa.com. I hope this helps you
Please vote
thanks
a
Can't get on internet. Dont have Ethernet Controller Driver
Im guessing u have an Acer pc, do u know which model is it? we need it to look for the correct driver. Did u formated ur pc at any time? maybe thats why u dont have that program.
1helpful
Adding an additional device. use the same software already installed to manage? or reinstall software?
WD says the software can manage several devices, so I think you don't need to reinstall... unless you got a newer version of the software, which would be able to manage the previous device.
To be really sure, start using the new device with the old software and see how it goes. You can always reinstall the software later.
Code 10 error loading audio driver for wxp. System does not recognize audio hardware.
this is any suggestion i have for u :)
install your sound driver manually.
go to control panel -->doble click system->click device manager->right click the sound device, update the driver then..
note :
(check the ethernet controller is that working properly?.. if not u need to update or reinstall the device first before update/reinstall any sound device)
good luck 4 u
3helpful
2answers
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Reloading software, Hard drive replacment
i hope u re install your operating system,
after the re installation u did not install the drivers that is the reson, best way u buy an ethernet card and try to get net connection and down load the drivers from dell.com ,then remove the card ,thats it.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
