The blower motor relay is energized when the Blower Motor Control is set to the High position. This removes the blower motor resistors from the circuit and battery voltage is then applied directly from the HVAC BLO fuse (RH IP Accessory Wiring Junction Block) to the blower motor though the relay switch contacts. The blower motor then runs at high speed.
HVAC Blower Controls Circuit Description
The blower motor is a variable speed motor. The motor operates at a higher rate when voltage is increased to the maximum level.
The blower motor resistors reduce the voltage supplied from the A/C FAN fuse (LH IP Accessory Wiring Junction Block) when the blower control is set at low and medium speeds (speeds 1-4). The blower motor relay is energized when the Blower Motor Control is set to the High position. This removes the blower motor resistors from the circuit and battery voltage is then applied directly from the HVAC BLO fuse (RH IP Accessory Wiring Junction Block) to the blower motor though the relay switch contacts. The blower motor then runs at high speed.
If the vents work,top middle, bottom. Most likely the mode door motor is bad. Usually at the center console under the dash. If the fan comes on at all. low or high speed, replace the blower resistor. Located by the blower.
U are on the right track. But check this out - is the low speed on the blower the only thing that is not working? Could be other things, such as lights that you are not aware of.
On some cars the low speeds for the blower work thru the ignition switch. If something is wrong with the switch the fan will work on high speed only but the lower speeds are inoperative.
On any other vehicle it sounds like the blower fan switch. The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor. But in your case the fan switch is part of the controller. I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged. If you have the model with 3 relays you may need to check them.
It needs to have the blower motor resistor card replaced. It still works on high speed because on the high setting the voltage does not go through the resistor. The resistor is mounted beside the blower motor and is easy to replace. There you are, thank you for using FixYa.
