Car Audio & Video Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace door speakers and install sub in 2003 sequoia
Anonymous
Level 3:
  • Master 655 Answers
  • Posted on Nov 11, 2009
Anonymous
Master
Level 3:
Answers
655
Questions
0
Helped
314419
Points
2081
Hello pdeve01,
I'd recommend searching one of the Toyota forums for specific installs in the Sequoia.
Or, you could just purchase your equipment from www.crutchfield.com and they will provide you with a free "master sheet" for your vehicle.
Rear speakers don't work after new head unit
There could be several reasons why the head unit for your car does not work. The most likely issue is that the head unit is not compatible with your stereo system. You can consult your vehicle owner's manual for speaker issues.---------------------------------------------------------------------------------------
Diagnostic VAG
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to www.speakerworks.com and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
I have a broken tail door knob on my 2003 toyota sequoia. Any idea how to fix this issue?
need to remove back panel.. make sure window is up. there is an opening . willl need i belive a 10mm socket. reremove lock actuator. then handle..replace and reinstall shouild take about 1 1/2 hours
1helpful
2answers
Back door handle broke.how do i get the cover off to fix it to open it again?
use a long screwdriver, approx 8in and skinny. Under the handle you will see the broken part on the right side. remove that part and insert screwdriver striaght up as possible, then point down to push lever inside door. REMEMBER to unlock doors first, after inside panels removed and license plate, you can remove the license plate box and replace handle
1helpful
How to replace a rear door handle on a 2003 Toyota Sequoia
This is a very common problem with the Sequoias (along with broken inside door openers).
Go to www.tundrasolutions.com and find the Sequoia section. There are numerous threads about the steps needed to replace this handle. Some go into great detail about the steps needed and offer fixes to keep it from happening again.
This design obviously has flaws, and Toyota should have acted to fix these flaws much sooner.
2helpful
2answers
My rear hatch door handle broke i need to replace it. how do i replace it?
how do i get the rear gate panel off so I can replace the latch on the 2003 sequoia.
2answers
Rear door latch replacement 2003 sequoia
Fig. The latch bracket shown is moved by loosening the mounting fasteners and sliding it as necessary. Matchmark the bracket to the door pillar before moving-1.8L Passat model shown
4helpful
3answers
Auto speaker wire diagram
FYI - I just took our 2004 Sequoia in because of speaker rattle coming from the front door speakers. Before I could tell them the problem, they guessed what it was. They see loads of Sequoias and Tundras with JBL systems due to the front door 8in speaker, basically, coming apart. His suggestion was to replace only the bottom 8in speaker, because the top tweeters usually are in good working condition. There is a minimal failure rate on the tweeters.
24helpful
8answers
2003 Toyota Sequoia Tailgate Latch - how to replace
Remove your tag bolts and remove the cover by pulling easy as not to break the tabs. The tag lights can but do not have to come out. At this point you can access the handle. You will find that the handle has a plastic arm that trips the latch by pulling a cable it will be broken. To open the door just pull on the cable. Once I open the door I removed the inside door panel and a metal cover which has about 8 10mm bolts it gives you more room to work.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
