Question about Proton MM2701VT 27" TV
I have a World Brand tv and I need the code so I can use my universal remote contro;l How do I find the right code to program my remote?
Need to reprogram GE remote to Samsung tv
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Program your GE Universal Remote using the correct code list and ...
GE Universal Remote Codes and Instructions ' direcTutor
www.directutor.com/content/ge-universal-remote-instructions
Direct Code Entry for GE remotes with 4 digit codes. 1. ... Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press ...
How to Program a Universal Remote - Frontier
internet.frontier.com/resources/how-to/program-a-universal-remote/
Here's how to program universal remotes from RCA and GE: ... with whatever device you're currently attempting to program (i.e. the TV, the DVD player, etc.) ... If you havea V2, V3 or V4 remote and are programming a DVD player, press PLAY ...
How To Program A GE Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-ge-universal-remote/
Feb 03, 2016 | GE Televison & Video
NH305UD. How can I program it?
Universal Remote Control Codes - Emerson Instructions
www.remotecodelist.com/remotes/emerson/emerson.html
Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For ... Emerson multi-brand remote codes for tv's.
Remote Control Codes For Emerson TVs ' Codes For ...
codesforuniversalremotes.com/universal-remote-control-codes-emerson-t...
2 & 4 Digit Universal Remote Control Codes For Emerson TVs Emerson multi-brand remote ... How to Program a Universal Remote Control : Universal RemoteProgramming of TV ... Can you give me the code for Western digital TV box please.
Emerson brand TV remote codes - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../Emerson...TV-remote.../784589
May 22, 2010 - I have a Emerson TV model # BLC320EM9 A and I cannot find a ...http://www.bing.com/shopping/logitech-harmony-300-universal-remote-control/p/7E7752820C88A8C05005?q=. ..... I can not get 11864 to work with the silver xfinity remote that has the ..... Code 11864 was not listed in the program guide.
Dec 25, 2015 | Emerson Televison & Video
Manual contro remoto universal keyston rm 702
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
May 15, 2014 | Televison & Video
I have a World tv with an rca remote(RCR3273N). Please, help find a code
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Apr 18, 2012 | RCA Universal Remote Control
Tv remote code for haier tv l24c1180a?
Hello
Four digit universal remote contro codes for Haier TV are:
0081 0216 0217 0157
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jun 26, 2011 | Televison & Video
I need to find some codes for a rca universal remote the model # is rcr312wv and its for a insignia tv.
Hello
Insiginia is not liste with the remote contro you specify here. It is possibe to get the code for your TV by search method.
Throughout the programming
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
Press and release the ON•OFF key
repeatedly until your component
turns off. Wait 4 seconds between
each key press. Each time you press
the ON•OFF key, the illuminated
ON•OFF key blinks, and the next
code is sent. The Brand Code
Search begins with the first code in
the chosen brand list for that
component and cycles through all
the codes for that brand. If your
component turns off, you have
found the correct code. (If it cycles
through and the illuminated
ON•OFF key blinks four times and
turns off, all codes in the chosen
brand lists have been searched. The
Brand Code Search mode is exited.)
Mar 23, 2011 | One For All URC-4021 Remote Control
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
I need program a new code contro JR 323
I found the codes in this page http://remotefinder.rca.com/
Codes for Jer 321, Jer 323 and Jer 422.
To introduce it to your universal control Jer 323:
1. Press the device button you need (for example, TV)
2. Press the input key and keep pressing it while introducing your code (for example, Sony Tv: "Input+1218")
Jun 02, 2010 | Jensen JER-422 Universal Remote Control
Need codes for a universal Philips Magnavox control for my insignia tv.
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 12, 2010 | Philips Magnavox Learning Universal Remote
Programming remote
i had direct tv went back to antenna but unable to get my local station now.
Jun 06, 2008 | RCA RCR311B Remote Control
Proton MM2701VT 27" TV Logo
995 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
