separtdifge3,
Probably a charge issue, try this:
1. Connect the reader to the computer for 15 minutes (make sure there is a red steady light)
2. Disconnect the reader and press the reset at the bottom
3. slide the power switch to turn it on
4. If the problem persist you will need to do a hard reset
5. If after a hard reset the issue is not resolve problably you will need to contact sony to get it repaires =(
eBookBoy
http://digialreader.freeforums.org
Yes. everything else seems to work fine. Just no screen. I turned it on to take a picture (I had used it the day before) and nothing. No display.
I have taken a couple of test shots and the pictures are on the card and downloaded normally.
Does the pictures download normally?
Does the photo's download normally?
