Re: i have problem with my canon ip1980. the ink...
You can open the printer case and look underneth the the ink cartridge ther are 2 ink absorbent foem remove it and wash it until ink remove from the foem make it dry and put it back again.
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
This may clear the ink absorber.
There is ink absorbers located at both ends of the printerwhere the ink head move. To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer. Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber. Closethe lid and the printer should now function normally.
The only way to correctly repair this fault is to service the machine
waste absorber pad needs to be replaced.
the waste absorber counters need to be reset
You can't. Here is what Canon says on their website:
Ink Absorber Replacement Options
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you feel your product might require service, Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
