Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
hi there, a little late.....but here we go........do you have cable? if yes connect the cable from the cable box out to dvd in and connect the dvd out to tv in.......pls note the dvd and tv must be set/tune to ch #3.(and you cannot record HBO)......you dont have cable just tv and dvd you need rca wire (red,white & yellow) also the F connector wire....in back of dvd connect the 3 wires audio in video in (is your tv/monitor a flat panal these connections might be on the side) if not its in the back plug in to out on tv....(this is so you can record)....plug the F conncetor wire from dvd to tv......on this connection you can set the dvd to ch #3 or any ch you want to record...........
If you use scart cables you almost cannot go wrong. You can either hook one scart from your DVD/VCR to the TV and one from the cable box to the TV, and switch using the A/V button on your TV.
Alternatively, you can hook one from your cable box to the "in-port" on your DVD/VCR, and one from the DVD/VCR to the TV. In this case you should be able to record programs from your tuner.
The full manual can be downloaded from http://www.tacp.toshiba.com/dvr/product.asp?model=RD-XS35 The cable box hook-up is on page 22. There are two ways:
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure.
From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables.
From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable.
From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right).
Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
