Televison & Video Logo
Anonymous Posted on Nov 09, 2009
I have had a DVD rejected by my TV with a message ''bad disc'' How come?
Howard Galley
Level 2:
Sergeant:
  • Expert 197 Answers
  • Posted on Nov 09, 2009
Howard Galley
Expert
Level 2:
Sergeant:
Answers
197
Questions
Helped
57253
Points
557
Dirty disc or laser, clean the disc and try again, also does the dvd work ok in an other dvd player?
2answers
DVD player not working!
The player uses a laser to check for a DVD. If the laser fails, the player acts like there is no DVD loaded and opens the disc tray so a DVD can be inserted. Sounds like a bad laser.
My DVD player willnot play commercial disc. It says no disc,bad disc,or no disc found. It is rejecting every disc I put in.
It is possible that the optical lens on you dvd player is dirty or worse it has gone bad. There are discs that are made to clean the lens. Here is an example : http://amzn.to/8Y4qSe
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
My JVC DVD recorder is refusing to playback one of my PHILIPS DVD-RW discs notwithstanding I have rec orded material on to it from the TV. The player is rejecting this particular disc coupled with a...
Did you record the disc on this DVR? Does it play in other DVD Players?.Try cleaning the disk with a soft cloth.Some DVR and Discs are not compatible.Good Luck.
3helpful
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
1helpful
Samsung DVD-VR 330 AK68-00995A-01 rejects all discs.
there could be dust on the laser. you can buy special cleaner or pull the machine appart and try to wipe the laser with a cotton budd and be carefull.
the motor could be blow?
Govideo can't recognize disc inserted-rejects
I have the same problem with mine. Tried the # in the manual but no longer works. Hope we get an answer!
DVD - Video Finalization rejection
1. The message can appear if the disc has already been finalised.
2. The disc may be faulty.
3. Try copying again from HDD to another disc. Performing a copy and finalise together by using 'DVD Video Creation' from the Edit menu can be more successful than doing each step separately.
4. When you transferred from your video camera, did you use firewire? If so, did you record at the maximum (default) bitrate of 14+ ? If so, you must copy (rate conversion) to the DVD at a maximum bitrate of 9.2, which is the maximum for the DVD playback standard.
DVD Recorder/Player won't accept DVDs
I think your Laser Lens or drive needs to be cleaned
1helpful
No DISC message displayed
Clean the lens by soft cloth by hand maually, lens cleaning will solve the problem
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
