you probably need to 'pair' the outdoor sensor with the main base: look for a 'channel' button, as these units usually can get information from several sensors and differentiate them by a channel number.
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
This is a very common problem that is most frequently caused by the outdoor transmitter going bad. They are surprisingly delicate and don't like getting wet.
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter 2. Remove the batteries from the main clock and keep them out until the clock display disappers. 3. Re-install the batteries in the clock. 4. Wait until the display returns and includes the outside temperature display as well. 5. Set the clock again for current time/date etc. 6. Bingo. You are in business.
Press set button repeatedly -you get timezone mode
and change your wished time zone (for help go through time zone codeing list) and select your zone then press set button to normal mode and adjust the current time.
