HI, The button is spring loaded. the mechanism is damaged. This will require you to replace the entire switch. There is no repair procedure for this type of damage. The spring has lost its structure. There are three styles. Most are recessive, and the glass should be removed, in order to dis-anchor the switch housing. If you can relay the entire model number, i will confirm the removal procedure. Thanks..
Ok, I have located a service manual that will guide you through the steps. This manual is very precious, and i would advise to download, and print it out asap. These manuals are very expensive,a nd very helpful, as well. Click Here to access this service/repair manual. Once the cook-top is removed, the switch will be exposed.
NOTE_ This manual covers all Jenn Air JED/JEC Electric Cook-tops.
On page 15, it tells you how to remove the top.
My Model number is jed8430adb and the serial number is 18042031cn. Can you provide instructions for the removal of the glass top so I can access the push button for replacement.
thank You
