What makes the bass1500 stay in Protection mode????
Ok, usually a fluctuation in amperage trips the protection on an amplifier. To start, check your ground. This is typically the problem. Use a multimeter to ensure that the ground you have is good. Second is the guage of wire. Look at the fuses on your amp. Add them together and use that as the amp draw total. 50-65 amps from 13 feet to 22 feet run of wire requires a 4 guage. If the draw is larger, you may need larger guage wire. Also, match the ground wire with the power wire in guage.
Happy Hunting
