HP 5590 ScanJet Flatbed Scanner Logo
Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What settings do I need to be able to have two or more pages scanned into the same file? I need to be able to have all the pages in the same file
Sean Wright
Level 3:
  • Master 2,045 Answers
  • Posted on Nov 09, 2009
Sean Wright
Master
Level 3:
Answers
2045
Questions
Helped
627112
Points
6368
In the scan options there should be a box to check for multipe scans or pages.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Scan multiple pages pdf
1, Double-click on the printer icon on your Desktop and select the Scan a Document or Photo option from it. Lift the Scanner lid and place the first page with scan side facing down.
2, Check the scan settings and click Scan document to file. Click the Scan button, and the scan process will begin. Now remove the first page and replace the second page on the scanner glass. Click on the "+" sign located at the left-hand side of the display.
3, In the same way, continue scanning other pages too. Once you completed scanning all the pages, click Done after saving the file with a file name.
4, You can change the destination name in the printer settings. In this way, multiple pages can be scanned as PDF.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
2answers
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Can you multi page scan, say 3 pages into one file, want to emaqil that file. Don't want to have to email 3 separate files. Re HP8500A
Yes, you can scan 2 or more pages in one file if you scan as pdf file and you use the top feeder to scanned multiple pages. SET YOU SCANNING FEATURES TO SCAN AS PDF not JPEG FILE.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
11helpful
Can I scan multiple pages to a PDF?
1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
3answers
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
1helpful
Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
http://files.support.epson.com/htmldocs/…
I think this says you need Professional Mode rather than Full Auto Mode.
Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
Basically, you keep adding pages then finish.
If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
Good luck,
- CarlD
I copied the text but I think you won't be able to see the images here:
4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
Select the settings that match your document and click OK. You return to the File Save Settings window.
6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
8. You see the Editing Page window displaying thumbnail images of each scanned page:
If you want to include all the document pages in your PDF file as they currently look, go to step 9.
If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
Note:
The delete icon is not available when all document pages are selected.
9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
7helpful
3answers
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
2helpful
2answers
Scan a Multipage Document into a Single File
My scanner is a Cannon but the basic jist of what your trying to do is universal. You need to open up the software for the scanner and look for an icon that says scan to file. It sounds like you have already done this. If so you are very close in the step I mention to the setting you need to scan multiple pages into one PDF file. Once you find the setting to scan multiple pages be sure to not click "FINISHED" until your last page is scanned in.
LB
Scanning software issue
if you go to scan settings under user tools you will see that you can set it to a multipage pdf or multi page jpeg tiff , or what ever , so if you scan 20 pages it will create 1 file and it would contain your 20 pages
k24674
Grand Canyon Tech
Grand Canyon Tech
