Symbol PDT 3100 Logo
Posted on Jan 06, 2008
Pdt 3100 I am trying to download physical inventory on to our computer and the 3100 keeps saying error 96 overrun. What does this mean and how do I fix it?
  • Anonymous Aug 04, 2008
    We have a PDT 3100 scanner configured an we can even pick items code up, however we cannot download the data to a PC.
    What we need y a software or configuration to download de information to a PC. There are only two fields in our application; employee number and the bar code.
    Thanks for your help.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 11, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1053
Points
I CAN HELP YOU IF STILL IN NEED.
PDT 3100 TRANSMISSION OF DATA TO A PC.
PC MUST HAVE WIN'98 OR WIN2000 INSTALLED AND ONE SERIAL PORT AVAILABLE : )
MORE INFO: [email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
814
Points
Microsoft Windows XP service pack2 not supporting
PDT 3100
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on Jan 09, 2008
Anonymous
Contributor
Level 1:
Answers
25
Questions
0
Helped
21282
Points
35
If memory serves me correctly it means you've run out of space on the Edrive (the part for data storage).
Try downloading a smaller file ...perhaps an old one you've backed up. it is possible memory is still available for them ..
Let me know what happens when you try the smaller file ... I'll look up the error if that doesn't solve the problem. I would look it up now ...but I'm at home.
What should I replace to fix error 0002, (Receive overrun error)
Hi
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
I am trying to run my pdt 3100 on my windows 7 operating system. I just bought a usb to serial DB25 Adapter and connected the docking station to the computer via usb. We bought this device about 10 years...
Hi Michael,
Sorry I could not login to Fixya yesterday,otherwise you should have received the reply mail early, but I just got busy due to some family problems.
Anyways, the product you have mentioned is PDT 3100 and you got to understand a few technical things which I would like to share with you now. First of all the PDT 3100 is 10 years old which is pretty older than the Operating System you are using which is windows 7 which is only 3 years old in market.What I am trying to say is any hardware device needs a driver software to run in a PC but the driver software which your device has was Last modified in 2004 so it is obvious it does not support windows 7.
Pleas check the detail here: http://support.symbol.com/support/browse.do?WidgetName=BROWSE_PRODUCT&TaxoName=SG_SupportGoals&BROWSE_PRODUCT.isProductTaxonomy=true&BROWSE_PRODUCT.NodeId=SG_PDT3100_1_2&BROWSE_PRODUCT.thisPageUrl=%2Fproduct%2Fproducts.do&id=m4&BROWSE_PRODUCT.TaxoName=SG_SupportGoals&NodeType=leaf&NodeName=PDT3100&BROWSE_PRODUCT.NodeType=leaf&NodeId=SG_PDT3100_1_2&AppContext=AC_ProductPage&param_document=sp
Also download the software from here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=KB100172&sliceId=&dialogID=261780565&stateId=0%200%2041932917
Please read the instructions carefully and download the software and install it.Don't get disheartened, install the software and see what you get, but I feel technically it should not work. but it will work on any Windows XP PC.so, if you have another PC with windows Xp your device will work.
Thank you for purchasing my service, i will be more happy if I can assist you even better.Do revert back if you face any further issue with the same.
Thank you one again.
Symbol 3100 pdt atho error missing confirmation number
are you recieving a full error message? What is the part number on theb ack of the unit. We specialise in legacy products and systems. We sell PDT3100's fully refurbsihed
We have several Symbol PDT 3100's with our old computer companies software downloaded on them. How do we delete these programs and set up the PDTs to be able to read and download as "text" files which we...
hi does your PDT 3100 have the Oneil's RSwin software if it does i can trade your PDT's for new ones. is the one that says Login Electronic Picklist record center Ops etc. etc. [email protected]
2helpful
2answers
Symbol PDT 3100 with own made program
The terminals use DR Dos as operative system. Anything you want to download to them normally has to be built into a hex file and you will need a cradle, a null modem cable and winhex or the old dos command called sendhex.exe.
Is it a pdt 3100, 3140 or 3146?
I can send you the operative system files if the terminal is a 3140 or 3146 or you can do a search on the web for LWP and UPD.
PDT 3100 Image
You need a cradle, a null modem cable, a pc running dos and the command rcvhex.exe which you can download from the net.
If you can get all this together, get back to me and I will give you full instructions on the process.
Programming a PDT3100 scanner
Hi there
First I need to know if you got the software that is on existing pdt3100 on a computer? once I know the answer to this I can start to tell you how install software on pdt3100's
mant thanks
Robert
3helpful
2answers
How can I download the data from de Symbol PDT 3100 to a PC?
We hava a Symbol PDT 3100 barr reader. It worls properly picking up bar codes fron our inventoy, however we don´t know hoy to dowload them to a PC. ¿Is there a software or configuration to download the data to a PC? Thanks for your help Jos? jalal
Simple application for pct 3100
there is a simple.hex on symbols website that should do the job.
acemods
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
