Apple iPhone 3G Logo
Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My iphone 2g wont turn on, i replaced the lcd, it worked ok, my batter was low. so it died and i was trying to turn it on, but it wont turn on. when i plug in the wall charger nothing happens,but when i press on the on button while charger pluged in, apple sign comes on for 2 second everytime i press on the on button, but it wont turn on. and if i try it without charged plugged in, nothing happens? any idea
Anonymous
Level 3:
  • Master 945 Answers
  • Posted on Nov 09, 2009
Anonymous
Master
Level 3:
Answers
945
Questions
0
Helped
370724
Points
3029
I have a feeling that when you ran the battery down it is now struggling to get and hold a charge.
If you have a friend with a similar battery perhaps try that, or go to a mobile store and ask them to try a new battery for you.
Iphone 2g won't turn on
Hello, friend! I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional unlock tools.
8helpful
7answers
Network problem using airtel sim in Iphone 3g
My problem is quite similar... My iphone works in some parts of delhi and it shows no service for other parts of delhi... If i use idea sim on my iphone, it works absolutely fine... and if i use my airtel sim on any other phone then also things appear ok..
any ideas?
Jan 30, 2010 • Cell Phones
MY iPhone 2g dies in the middle of resetting.
omg this happend to me too!!! UPDATE ME IF YOU FIND AN ANSWER!
3answers
Bottom row of my keypad doesn't work
You have to get it changed
2G iPhone - FULL LCD with Touch Pad !. 3G iPhone - Only Touch Pad !
Best Regards
I put my iphone on charge, and after 5 min. i needed to make a phone call, i clicked on the menu button, then slide to unlock, tried to type my passcode but u cant click on them they just wont work, and i...
This is because your battery is so flat it doesnt even have the power to turn off properly,and the program does often get "stuck" when this happens. Remove the battery, recharge the phone and it should be ok.
Slider on my iphone 2g wont work
Your LCD assembly is going bad.
or has gone bad.
Is your phone unlocked?
if so some unlockers will also cause this malfunction.
But most likely the digitizer in the lcd assembly is bad.
if it is a 3G you can replace the outer glass and digitizer for around 40.00 for the part and 35.00 labor.
good luck
My iphone 2g wont charge & wont turn on
Try using another cable or charger. A damaged charger or cable could cause it not to charge.
Otherwise, contact apple or apple store for repair.
Iphone 2g unlocked,cannot connect w/ edge. wifi is working
Jailbreaking your iPhone to 2.2 is going to mess up your phone. I've got a jailbroken 2.2 iPod Touch and it's ok - a friend of mine also tried to jailbreak his iPhone to 2.2 and lost connections as well.
Downgrade back to 2.1 and you should be ok.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
