Question about KLH ASW10-120 Subwoofer
No sound and smells like burning - KLH ASW10-120 Subwoofer
  • 547 Answers
There are a lot of folks who've had power supply issues with this sub. Typically, the large resistors fail, which takes out the capacitors.
If you know how to read schematics and replace parts, then these might be helpful to you:
Here are the two pages of schematics from KLH. I wrote to their techdepartment and explicitly asked for permission to share them here.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
Posted on Nov 21, 2009
  • 57 Answers
Hi there.
The speakers are possible burning/the wirecoil. The crossover is also sensitive to high power play. Replace???
Iceman.
Posted on Nov 10, 2009
SOURCE:
My sound system had a smell of burning from the main unit and suddenly stopped working. I switched it off and now although all the function lights are on there is no sound from the system but no longer a...
radios often have components that over heat and burn out. Once burned out they have to be repaired or replaced. Ford F150 trucks are notorious for that.
Mar 02, 2015 | Cars & Trucks
Burning smell and rattle sound
The rubber drive belt is burning up most likely cause by bearing going. The bearings are your ratteling sound and the burning smell is the rubber belt dragging.
Apr 08, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Gears arent going and no acceleration and burning smell
You need to have a look at your clutch. The burning smell is the clutch slipping.
Mar 22, 2014 | 1995 Holden VR Statesman
Smells like burning electrical
Its sounds to me like maybe the belt is slipping that will smell like something burning.
Oct 07, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Battery light on and a strong burnin rubber smell
SOUND LIKE ALTERNATOR SHAFT BEARING FAILING CAUSING ALTERNATOR PULLEY LOCK OR PUT DRAG ON DRIVE BELT CAUSING BURN RUBBER SMELL OR DRIVE BELT LOOSE CAUSES BELT SLIPPAGE MAKE BELT RUB AND BURN.WHEN YOU SMELL RUBBER BELT BURN SMELL WATCH OUT DRIVE IS GOING TO BREAK.
Aug 04, 2011 | 1983 Ford Fairmont
I just bought a 1996 camry and the fan sounds loud and it smells like something is burning, yet the temperture is normal and no smoke comes out. Is that Normal? First Toyota, so I"m not sure if the...
Check the fan on broken blades - even a small part missing can cause unusual sounds. If parts are new / serviced - smell can be due to labels getting hot and emitting slight burning smell. Classic are exhaust pipes with partnumber labels left on there. If he smell stays, something in the interior might come from a crash car which was partly burned.
Jun 30, 2011 | 1996 Toyota Camry
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
Winding sound, with a smell of burning
I recommend to stop the use of the dryer immediately and call an expert repairman to your home. The smell of burning can only mean bad things, so better safe than sorry.
Dec 29, 2008 | Indesit WA 125 Front Load Washer
KLH ASW10-120 Subwoofer Logo
712 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
