I have the TV connected to my cable box via component video inputs at 1080i, and as I am watching, at random times, the picture goes black, says "No Signal" and then comes back again. This only happens with the cable box, not when I am watching a DVD (also connected via component video). It seems like maybe the cable box is dropping the signal or switching the resolution. I don't think it's a hardware problem with the box becuase I tried another one and I have the same problem. The cable box is a scientific atlanta explorer 8300HD.
Any ideas as to how I can keep a consistent picture on the TV?
My best guess is the signal to the Cable box. It is not a hardeware problem if you replaced the box it has to be the cable signal. Loose connections are sometimes the problem.
World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
32 inch LCD TV with 3 HDMI inputs and PC input
USB input for direct media playback
45,000:1 Dynamic Contrast: While viewing either very
bright or very dark scenes, it can be difficult to distinguish main
images which blend into the background.
Dynamic Contrast dramatically mitigates this problem by
adjusting the backlight intensity, providing up to a 4X improvement in
contrast.
6.5ms Response Time
Widescreen 16 X 9 Format
World-wide Dual Voltage 110-240 volts 50-60 hertz
HDTV monitor (HDTV tuner required for HD reception)
This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
To watch digital channels (ATSC Broadcasting in US and DVBT
broadcasting overseas) you need a digital source/tuner like a cable box,
digital tuner, satellite service, etc.
To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
Component Video Input offers the best video quality for
DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p
and 480i) connections.
PC Input allows you to connect your PC and display the PC screen on your TV.
Your TV will display all High Definition signals as 1080i True HDTVâ„¢ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
For connections of audio, so that you can hear all tv audio through the surround system, connect either an optical audio cable or red & white analog audio cables from the tv to the home theater. If you are using optical audio, there is a plug on back of tv labeled for digital audio output and an input on the surround sound system. If you plan on using analog red and white, use the PROG OUT red and white output jacks on the back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or Component cables. HDMI is the cable that will provided 1080p signal (the best HD signal), but if the source does not output 1080p, then your tv will not display 1080p. Most cable boxes output at 1080i or 720p when on HD stations. This signal still provides great picture quality, but HDMI is not needed to get these HD signals. You can use component cables for your cable box and the DVD player output to the tv for video. HDMI might give you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the tv (component or hdmi). Also from the home theater system to the tv using hdmi or the video cables from component (red, blue, & green cables).
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Hey smittybd, According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections. If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation. Hope this helps you out. Sincerely, Aaron Go Ahead. Use Us.
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
This set does not support 480I in the DTV mode, only 480P and 1080I is supported.
Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs.
Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well.
Hope this helps.
