GPX RDT4004SP AM/FM Radio Logo
Posted on Nov 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bad reception fm radio signal
Bad reception on FM radio signal, AM signal strong
Anonymous
Level 3:
  • Master 317 Answers
  • Posted on Nov 08, 2009
Anonymous
Master
Level 3:
Answers
317
Questions
Helped
98968
Points
1237
Usually batteries...am takes less juice.....battery strength will affect fm signal strength
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory » FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Fm works, am does not
Check the antenna connection. A poor connection will often be good enough for FM but make AM reception so bad the the radios auto-gain circuits will mute the output unlike old AMs that would just produce loud static in poor signal conditions.
1helpful
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Improve reception
    HI there,
    Well Yes you can improve the reception, please follow the below steps -
    Improve FM Radio Reception -
    1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
    2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
    3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
    4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
    5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
    Improve AM Reception -
    1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
    2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
    3. Plug the radio into a different AC outlet.
    4. Move the radio closer to a window.
    5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
    6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
    7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
    Good Luck!!
    Thanks
    3helpful
    !994 Park Avenue FM radio reception poor. AM signal OK
    Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
    2answers
    JVC detachable face with auxillary input
    You may have a bad antenna or antenna cable.
    FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
    SL100 static and bad FM reception
    I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
    Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
    Good luck.
    Top GPX Audio Players & Recorders Experts
    SmartAviator
    SmartAviator
     Grubhead
    Grubhead
    Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
