Seiko Chiming Pendulum Tambour Mantel Clock Watch Logo
Posted on Nov 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The pendulum stopped swinging...the clock and chimes work well
  • Anonymous Mar 13, 2014
    pendulum doesn't work. clock time works fine, but pendulum doesn't swing and doesn't seem to work even with a new battery.
Anonymous
Level 3:
  • Master 714 Answers
  • Posted on Jan 21, 2010
Anonymous
Master
Level 3:
Answers
714
Questions
Helped
316770
Points
1893
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beThe pendulum stopped swinging...the clock and - clutch.jpg always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
I have a wall clock, with metal 'scroll work' the clock runs but the pendulum doesn't swing. How to repair the pendulum mechanism?
If your wall clock is running but the pendulum is not swinging, it may be due to a few potential issues with the pendulum mechanism. Here are some steps you can take to repair the pendulum mechanism:
  1. Check the suspension spring: The suspension spring is a thin strip of metal that hangs down from the top of the clock and holds the pendulum in place. Check to see if the suspension spring is properly attached to the clock and if it is straight. If it is bent or damaged, it may need to be replaced.
  2. Check the pendulum leader: The pendulum leader is the part of the clock that connects the pendulum to the clock's movement. Make sure that the pendulum leader is properly attached to the clock and that it is not bent or damaged.
  3. Check the escapement: The escapement is the part of the clock that controls the swing of the pendulum. Make sure that the escapement is properly lubricated and that it is not damaged or jammed. If it is damaged or worn, it may need to be replaced.
  4. Check the beat setting: The beat setting is the adjustment that ensures that the pendulum swings evenly. Make sure that the beat setting is properly adjusted by moving the pendulum to the left or right until it swings evenly.
  5. Check the weights: If your clock has weights, make sure that they are properly attached and that they are not obstructed or damaged.
If you've tried these steps and the pendulum still isn't swinging, it may be best to contact a professional clock repair technician for further assistance. They will have the expertise and tools needed to properly diagnose and repair any issues with your clock's pendulum mechanism.
Feb 18, 2023 • The Watches
2answers
Daneker grandfather clock
Yes chiming clocks always have a switch to turn them off. Often termed a 'night shut off'.
https://www.google.com/search?q=daneker+grandfather+clock+turn+off+chimes
Nov 07, 2021 • The Watches
1helpful
Is it possible to have a pendulum that is too heavy? The grand father clock is battery operated and the part that swings the pendulum will move back n forth when the pendulum is not on it. If the weight...
It is a handsome longcase clock and rather elaborate - it would be disappointing to discover the weights and pendulum are merely decorative.
I have only encountered one similar clock and it had one battery to keep the pendulum swinging and another to power the clock. The battery had to be fairly fresh or the pendulum stopped swinging. The clock also had to be level or the pendulum stopped.
If you took the picture when the pendulum was stationary, the clock appears not to be standing vertically. It is important they stand vertically in both planes to the nth degree.
There is also a fable about a clock never being happy standing next to or hanging on an exterior wall, sometimes not such a fable...
I don't think the pendulum is the problem. I suggest you should level the clock (considering the shape of the case a plumbline would be best), fit a new battery and give the pendulum a swing - if it doesn't keep swinging, there is probably a fault with the motor.
Oct 24, 2020 • The Watches
2answers
This clock has been in my family for manyyears and it has recently stopped working. The pendulum no longer swings continuously and i dont hear a ticking when i do swing it. My grandpa said something about...
It sounds like the drive spring might be worn. A Good clock and watch specialist will be able to overhaul and service the clock for you. It might cost you a bit more money but if it is a family clock it could be worth it.
Dec 13, 2019 • The Watches
I have a Colonial Grandmother clock,it will run about 10 mins, it tick, tocks, hand moves as pendulum swings ,will chime, then stops running,
Could be it needs cleaning or servicing though perhaps it isn't sitting perfectly level
The "old wives" tale of clocks failing to run reliably against an outside wall aren't unfounded.
Apr 27, 2018 • Watches
I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
Perhaps your is the same?
Mar 13, 2011 • Watches
2helpful
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 • Watches
1helpful
Bergen Enkheim Clock won't stop chiming. The pendulum does swing and it is would up.
It sounds as though part of the mechanism that controls the chiming is jammed. This could be caused by dirt or wear.
I suggest you have the clock cleaned as a first step and ask if there is any sign of damage.
Jan 04, 2010 • Watches
2helpful
What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
May 02, 2009 • Watches
Top Seiko Watches Experts
Paul Bade
Ngoro
Are you a Seiko Watch Expert? Answer questions, earn points and help others
