How can I change the battery in brio train 512
Hi Tarja, your question is 4 years old, but here is the answer:
You've probably seen the odd shaped tiny screws on the underside of the train. Ignore them - they require specialized tools and only lead to the wheels and gears.
You just need to insert a small cross-tip screwdriver into the exhaust funnel of the engine and remove the screw completely. The black front of the engine comes off and reveals AAA micro batteries which you gently shake out of the engine and replace.
As ever so often - once you know how to do it, it is very easy.
And - no, I didn't find out myself either *grin*
SOURCE: Hi, any chance you can
There is a small screw hole on top of the train, down inside what looks to be the smoke stack. Then insert 2 AAAs!
SOURCE: Brio Mighty Red 512 - Battery help
Easy to do. You'll find a small phillips screw located at the bottom of the black smokestack. After unscrewing it, lift up the entire front black part and you will see two AA batteries inside the body of the locomotive. Careful not to strip the screw when replacing the black smokestack part, as it is the only thing holding it down!
SOURCE: how to change the battery in Brio's mighty red
If you look in the funnel there is a screw. Undo this and the front comes off and the batteries will pop out. Put in the new batteries and replace the funnel and screw.
SOURCE: Brio remote control express doesn't move anymore
I wish I could help - I have exactly the same problem! Train opened Christmas Day, worked ok. Batteries seemed to gradually die 2-3 days later. Replaced all 3 sets of batteries twice, but nothing. Initially I got sounds, but nothing now.
SOURCE: My Brio RC train Express model, does not work,
Hi, Im actually looking for instructions for this train online? cant find any?
But....
I think your problem may be down to the fact that the train itself has 2 separate battery compartments! one in the front carriage holding 2 x aa batteries [which powers the wheels and headlamp] and one in the rear carriage which holds 4 x LR44 button cells [to power the rc link and sound effects] not obvious.
What I want to know is what are the little black and red buttons for?
