Question about Curtis-Mathis CM19011 TV
Ant/cable During a power outage, I used a generator to run tv. Cable was out so I hooked up rabbit ears. When power came back on I hooked cable again but cannot get reception thru cable box. When cable is hooked up directly, it works but not through the box, which has premium channels. Pushing the menu button, I can't find a ant/cable selection. Any ideas?
    Sergeant:
  • 284 Answers
Your box might be blown out
also call the cable company to see if the outage didnt affect them
they might be out too
on the TV you might to look for setup or init setup
a model number of the tv set wouldnt hurt too
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Jun 14, 2008
SOURCE:
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
Just purchased an RCA 32" LED TV from K-Mart. Trying to set-up and in auto-scan it will not pick up any channels
It really depends on how your connecting signal. I am not sure about where you are but virtually all cable companies in Canada require the use of the cable box. Searching channels will only check either the analog cable input or rabbit ears. Typically you hook up the cable box via HDMI and set the televsion to that HDMI input and channels are changed on the cable box.
Dec 07, 2014 | RCA Televison & Video
How to hook up T V ears on 32 " element tv ( elucfw329 )
every since television went digital, rabbit ears are hard to get to work. you will probablty have to get a digital converter box for it first, attach rabbit ears to converter box and box to television the same way you would attach cable
Jan 16, 2014 | Element Electronics FLX3210 32 in. LCD TV
Can't program the tv to go past channel 14 should the tv be on ant-A or cable
TV -if your using rabbit ears or anttena on the roof.
Cable -if you are a cable subscriber
Aug 04, 2009 | Televison & Video
I have a Magnovox video cassette & dvd player combo, model # DV200MW8. I have an RCA analog TV with 1 cable port in the back and 3 RCA jacks ports. Previously, my Maganavox VCR/DVD player was connected...
omg , haven't heard the word VCR in decade.
are you kidding? seems not.,
what's next 8track tapes? and Beatles? LOL ! "hard days night?"
omg 2, rabbit ears,, im blowing out a gasket laughing...
vhf/uhf analog tv is gone. now. (FCC rules ,dead) HDTV sure.
please say what you are up to the job.?
are you trying to burn VHS tape to DVD? nah.... that be me 16 years ago.... then gave all my VHS away at work. hated VHS, ugly mess.
i see, says the blind man!
you need a switch box.
yes, they still sell them like on ebay but not walfart.
Mar 13, 2017 | HP Compaq Presario V5204nr Notebook
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Sanyo dvw 5000 setup
If you rabit ears have a ribbon cable you will need a coax adaptor. Radio Shack carries them. If you cant find them, you might have to get a set of rabit ears that has coax wires. The antenna will plug into the cable in of the DVR. You take the coax output and plug that into the tv using a coax wire.
Aug 04, 2008 | Sanyo DVW-5000 DVD Player/VCR
No HD
Your TV has a built in tuner but NOT a built in antenna. Depending on where you live (distance from broadcasters) you will need to add anywhere from rabbit ears (with the UHF loop) to an antenna on the roof or mast.
If your home already has an antenna installed, connect the coaxial cable to the back of your TV. Then go to "Set-up" and scan for DIGITAL channels. If you are trying rabbit ears, do the same.
Mar 15, 2008 | Protron PLTV-4250 42 in. LCD Television
Curtis-Mathis CM19011 TV Logo
102 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Vitally Alcher
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
