Watches Logo
Posted on Nov 08, 2009
How do you turn off the alarm on the Bijoux Terner Sport Watch? I managed to set it but cannot figure out how to turn the alarm off.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1661
Points
14
How do you set the time on terner sport watch R1005M
To set the time on a Terner Sport watch R1005M, you'll typically need to:Press and hold the "Mode" or "Set" button until the watch enters the time-setting mode.Use the "Start" and "Stop" buttons to adjust the hours and minutes.Press the "Mode" or "Set" button again to save your settings.Please note that the specific steps might vary depending on the exact model of the watch, so it's a good idea to refer to the manufacturer's instructions provided with the watch for precise guidance.
Nov 04, 2023 • The Watches
How do I set time on my Bijoux Terner Sport R0719M?
ur asking the wrong place - try the new invention - google it
Mar 10, 2015 • Watches
4helpful
Instructions for Armitron All Sport 40/6623 time setting needed.
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
1helpful
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Terner sport watch need instruction manual
how to get watch back to am and pm it's on H
2answers
Bijoux Terner ''Sport'' digital watch, model R0803M. Module appears to be WR30M. Setting sequence seems to be messed up...
If you are having trouble setting the watch there could be an issue with the movement itself! I suggest taking to a watch repair business and having them take a look. If the movement is bad it shouldnt cost too terribly much to replace it.
Jan 08, 2010 • Watches
7helpful
Can't get watch off of military time and not sure how to set time, date ect
how do u get the military time off a TERNER SPORT NICKEL FREE watch
Jun 04, 2009 • Watches
13helpful
3answers
Bijoux Terner Sport Watch Trouble
japgap has it pretty much right .... Start by pressing the Mode Key. It should change the mode (probably to stopwatch first on first press, alarm if Mode Key is pressed again, then time if pressed a third time). (NOTE: pressing the Mode Key to get action isn't about the length of time pressing the key, its about getting a "connection" when pressing!!! The sport watch doesn't have the greatest quality construction so a simple press does not always make a connection).
Once in the time mode, the seconds will be blinking, press the Reset Key to move to minutes and Start Key to advance the minutes, then Reset Key to move to hours and Start key to advance the hours. Mode Key to get back to regular operation.
Aug 24, 2008 • Watches
45helpful
2answers
Bijoux Terner Sport watch RO616F
I got one of these on a cruise, and I had the same issue, and searched on the web just now (7/26/08 9:20pm) and could not find an answer.....so, I just sat here for a few minutes to push all the buttons...
Mine has 4 buttons at the 2, 4,8,10 positions....corresponding to "start", "reset", "mode", "light"
Hold down the "start", then while holding it down, push the "reset" button.....voila!
123helpful
3answers
Instructions for a bijoux terner sport watch
hello,
my watch is bijoux terner sport R0607L
here is scanned manual: http://i280.photobucket.com/albums/kk197/somber_glass/scan0003.jpg?t=1226240017
I hope it would be useful :)
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
