Re: The automatic shutoff won't let the iron heat up
You either need to press a small button on the protection to reactivate it, or buy a new one and replace it. But first check the thermostat, since there is a reason for all this. Check also the heating element with an ohmmeter.
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary. God bless you
test the 1) fuse heat and replace it 2) test the board if there are voltage , if there are the board can be faulty or repair. 3) see your instruc. manual go to the section troubleshooting and see what is wrong. God bless you
1) test the power cord 2) no power to receptacle 3)open thermostat 4) open the heating element 5) defective main switch. 6) if you iron has electronic control the board can be faulty. see the diagram God bless you
The most likely cause is a faulty temperature sensor. The Iron is most likely shutting itself off because it believes that it is already at the correct heat. The less likely scenario would be a faulty heating element. In either case you will not be able to fix this yourself.
Check that the Iron is correctly plugged into a working outlet as that often tends to be the solution we all miss.
There is a thermal fuse in the iron which blows when overheated. This fuse has to be replaced.
You can probably find one on-line at radioshack.com -- match the temperature rating of the old fuse. It'll have to be crimped in -- if you solder it, the heat will blow it.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
