You may just have a stray fault, try to clear it and see if it returns: Key ON, Key OFF, Key ON, hit left turn signal 2 times wait for 2 flashes,,, hit right turn switch ONCE =>One Flash. Hit Right switch once =>2 flashes, Hit right turn switch once again =>3 flashes. Hit Left turn switch once than read codes to clear Hit left switch & hold for confirmation 2 flashes (hold at least 5 seconds).
If the code comes up again you've got a poor ground issue somewhere.
Many people have complained that there built in flash justs pops up, but it wont light up. Here is a fix : Remove the 2 screws from the front of the popup flash The rear plastic cover will the clip off. Inside you will find a small switch on the right side of the flash unit when it pops up the switch should make, if it doesn't try shorting it with a small insulated item the try the camera in low light and see if if flashes. To fix you need to remove the spring-screw from the other side then gently prise the bracket off, then just pull out the small white sleeve on the right hand side of the popup near the switch, this sleeve moves in slightly and will not make the switch on the popup flash. Gently put the flash bracket onto the camera, be very gentle as the wires are very thin. You will see the white plastic bearing has 2 small clips which need to be through the hole on the bracket the pin which activates the switch will then be in the correct position.
You have to place your right thumb & press firmly in on the right lower side of the flash (4AA Battery Magazine Cartridge) while holding on the left side with your left hand.
Press firmly in & then slide it down with your thumb.
I have a couple of Fuji S700 cameras and one of them recently came down with the same issue. The flash would partly open but not pop up all the way. I decided to open the camera up and find out what was really wrong. It had been sticking before and the above suggestion about blowing it out helps, but this issue is where it unlatches, pops up part way but doesn't go all the way up and if it doesn't go all the way up the flash doesn't work.
The problem is there is a spring insite the flash hinge that pops the flash up once the electronic latch is opened by the auto exposure circuitry. One end of the spring goes into a hole on the part of the flash that pops up and this plastic part is simply too thin for the force on it and it breaks over time. Bad design.
I should say I first thought about a couple of workarounds. One was real easy if you are not too handy. Take a small rubber band and run it from around the eyepiece to around the "lobe" under the flash. When you weant to use the flash, depress the shutter half way to unlatch it, then move the elastic from the lobe to under the raised flash and it will hold it up. You can leave it up all the time if that works for you. It didn't fit my case with the flash up all the time so I decided to forge ahead... Buying a new case might have been a wiser choice :-)
By the way, its not easy to get into the flash area. I pretty much had to completely disassemble the camera, and I got in a fight with a very high voltage capacitor for the flash that holds its charge for a VERY long time after the batteries are out AND it holds enough charge to get you a few times so use a resistor to discharge it when you get into that are or else... be afraid, very afraid. Seriously. Before you disassemble read on...
If you had a very tiny right angle philips screwdriver you could probably do this repair without taking things apart. The key is there are two screws that hold the top cover of the flash area on. This is the area you need to get at to fix this spring. These screws that are only accessible when the flash is popped up and even then you can't see them as they are recessed. If you can get those screws out somehow then you can do this without a nightmare. If you take the whole thing apart then welcome to hell. I am just on my way back from hell. Hope mine works when I get it back together.
I chose to epoxy a small bent pin in to replace the broken plastic part. I used a long square wire wrap pin, bent it to the right shape and cut it to the right dimensions then glued it in place using epoxy. There is a fair amount of room for glue in there, but be careful not to get it into the area where the lower shaft has to slide back and forth as the flash pops up and down. I used 5 minute epoxy and first just used a tiny dab to hold it in place and I positioned it carefully and let that set. Then I did another glue job to add some strength. Position, then reinforce.
These pics are not the greatest quality, taken with my iPhone, but once you take your flash cover off it will be pretty obvious what 2 U brackets are under the L bracket (that hooks around the mount). Make sure the two U shaped brackets are LEVEL with each other, mine had 1 tucked down & as soon as I used a small screw driver & pulled it out to make it even, I pushed the flash down, hit my button to pop the flash up & it released. Please remember!!! When the cover is off & you engage the flash there is a chance that the flash bulb will shift up & can potentially fall out. I would put the black flash cover back on before you engage your flash to keep this from happening, otherwise you could get a jolt from the electrical system trying to put your flash bulb back in (speaking from experience). Good luck!
it screws into the mount underneath your camera, connects via a cord to your hotshoe mount, and your flash willl then sit next to your camera mounted on this flash bracket.
A change was made in the flash power connector on later Nikon Speedlights and the Power Bracket Model SK-6. It is impossible to connect a flash with the older (square) connector to a newer SK-6 or vice versa.
The flash on the left has the older square-style connector, while the one on the right has the newer connector. Both the Speedlight and the SK-6 must have the same style connector. Please contact Nikon Service about having the units modified for compatibility.
The flash on the left (above) has the older square-style connector, while the one on the right has the newer connector. Both the Speedlight and the SK-6 must have the same style connector. Please contact Nikon Service about having the units modified for compatibility.
