Nikon D80 Digital Camera with 18-135mm Lens Logo
Posted on Nov 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Err message appears on the display of my D80.
Err message appears on the display of my Nikon D80. I checked batterries , memory card and lens contact. Any suggestion ?
Ozzie Morrow Jr.
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Nikon Expert 305 Answers
  • Posted on Feb 11, 2015
Ozzie Morrow Jr.
Nikon Expert
Level 2:
Champion:
Cheetah:
Answers
305
Questions
Helped
65763
Points
398
Just reset your camera you did something wrong
Turn off camera pull battery out put back in pull card out and put in correctly uncouple your lens then put back on
Now you good to go.
Anonymous
Level 2:
Novelist:
  • Expert 181 Answers
  • Posted on Jan 04, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
181
Questions
0
Helped
86263
Points
305
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
'err' sign on display nikkon D80, and appear r 15 when shutter button is press
"rXX" is just the camera estimate of how many pictures left on memory card. As for "ERR": while camera is in "On" position, take out battery and hold shutter button approximately 30 seconds. Turn camera "off, replace battery and turn "On" again. If thre is a hardware reset button (check manual carefully) while camera is "On" use that reset button/
4helpful
I've given up trying to remove the "err" message from my D80 . I've done everything that was suggested ! removed the lens , cleaned the lens contacts , removed the battery and added a new...
"ERR" is camera error. Two items to try:1/ remove battery while camera is ON while waiting for approx 30 seconds, press and hold the shutter release, insert battery and give it a go. 2/ if there is a camera hardware reset button try that with camera ON. There may be a firmware update on Nikon web site, but if you cannot read the memory card, you cannot install it.
www.nikon.com Choose your country/area and go to support
2helpful
I have a D80 since 2 years and since last 1 week have been getting the 'Err' message. Initially, after referring to the manual & pressing the shutter release button, the camera responded only ONCE. ...
Hi sandeepbhat2, On page 129 of the D80 manual is the factory reset switch. Look on the left side of the camera there is the terminal cover, inside below the USB connector is a small reset button. Give that a try. If still it does not work you should call Nikon.
My d80 keeps reading error, i have tried adjusting lense and changing memory cards, don't know what else to try
What is the error message? If it is ERR then ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go call Nikon digital 1-800-645-6689.
6helpful
2answers
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
2answers
While my Nikon D80 is Error 09, can I update the firmware?
Have you e-mailed or called the techs at Nikon with your problem?
2answers
Nikon D90 ERR message after taking picture -
Is there a memory card in the camera?
Also try cleaning the contacts on the lens (light rub with a pencil eraser works).
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
