Dear sir/madam I bought a kArcher model K3.97 about a year and a half ago but the cyclone nozzle will not spin for more than 3 seconds , it seems that the ball bearing gets stuck how could this be rectified . By the way its a water blaster thank Peter c
Peter , sorry to say but there is no replacement parts for that lance , you just replace the entire thing
its called a Dirtblaster lance
Had same problem, you can unscrew the nozzle from the lance, remove the white plastic insert (pull out with a pair of pliers) and remove bearing and jet. Give everything a good clean including the 4 pin holes in the white insert (at 45 degrees) that create the cyclone effect, replace everything make sure the insert is flat or level in the nozzle, I have found that if its not flat or if its overtightened or any dirt it will overpinch the bearing amd it will not rotate.
A little crc or similar down the spout will fix it, i had the same problem...
